Previous in Blog: Gunsmithing Tools for Rifles and Shotguns   Next in Blog: How to Maintain Rifle Chambers
2 comments
Gunsmithing Tools for Pistols and Revolvers
Posted January 19, 2015 1:23 PM by Brush Research
Handgun maintenance is essential for the proper functioning of semi-automatic pistols and revolvers. Flex-Hone for Firearms tools from Brush Research Manufacturing (BRM) remove build-ups of primer, gun powder, and ammunition casing materials from handgun cylinders. BRM's gunsmithing tools also remove surface irregularities such as machining or tooling marks. For cowboy action shooters, these reliable brushing tools are a good choice for removing residues from wax bullets.
Flexible honing for handgun cylinders imparts a finish that's free from these and other surface imperfections. BRM Flex-Hone for Firearms tools also impart a series of regular grooves that promote optimum lubrication. Firearms manufacturers, gunsmiths, gun collectors, and handgun owners alike also appreciate how flexible honing imparts a surface finish that looks great and helps to protect gun parts from fouling and corrosion.
Handgun Maintenance
As an experienced supplier of surface finishing solutions, Brush Research understands the needs of the firearms industry. Without proper maintenance, semi-automatic pistols can experience misfeeds, failures to eject (stove pipes), and misfires. Residues on the follower, feed ramp, bolt face access, or extractor groove can prevent a cartridge from chambering properly. Build-ups at the chamber's breech can keep cartridges from fully loading, leaving the bullet rim unsupported.
Revolvers can also malfunction if they're not maintained. For new shooters, it's important to remember to hold the muzzle upwards while extracting spent shells. Otherwise, burned powder residue and unburned gun powder can become lodged under the star extractor, preventing the star from fully seating in the cylinder recess. Problems associated with a residues can also affect experienced shooters, which is why periodic gun maintenance is so important.
Flexible Hones for Handgun Cylinders
BRM supplies chamber hones for a variety of handguns, including .32, .357 MAG / .38 cylinder, .41 MAG, .44 MAG, .45 ACP, .45 Colt, and 9mm. These Made in the USA Flex-Hone tools have a 1-5/8" abrasive part and an overall length (OAL) of 3 inches. Depending on your surface finishing requirements, choose silicon carbide (SC) abrasive in either 400 or 800 grit. If a surface requires significant improvement, start with a lower-grit tool and then use a higher-grit tool for the final finish.
Flex-Hone for Firearms tools are also available for maintaining the slides on semi-automatic pistols made by Smith & Wesson, Beretta, and Sig Sauer. These 800-grit SC tools have an overall length (OAL) of 8 inches. Handgun owners can also choose gunsmithing tools for the slide lug area or the main spring housing in Model 1911 firearms. M1911 pistols are used by military and law enforcement personnel, and remain a favorite of recreational shooters.
Visit BRM at SHOT Show 2015 (Booth #2828)
Do your tradeshow plans include a visit to SHOT Show in Las Vegas from January 20 to 23, 2015? Visit BRM in Booth #2828 at the Sands Expo Center and learn more about Made in the USA surface finishing tools for semi-automatic pistols and revolvers. Our technical team is ready to answer your questions, and can tell you more about the handgun maintenance tools shown in this new YouTube video. To arrange a meeting, contact BRM today.
Author's Note: This CR4 blog entry originally appeared in the BRM Flex-Hone Blog.
Re: Gunsmithing Tools for Pistols and Revolvers
01/20/2015 10:04 AM
Why would I want to remove material from a precision fitment?
For every great advancement in medicine there is an equal and opposite advancement in the denial of treatment.
01/20/2015 6:24 PM
To turn a .44 into a .45 maybe?
