From Medgadget:
MIT Tech Review has a report about the latest efforts by nuclear engineers at MIT to develop a technique that uses not only absorption, but also refraction of the X-rays, and improves diagnostic capabilities of radiography:
When radiation hits a material, many other things happen to the waves besides absorption, say Richard Lanza and Antonio Damato, a research scientist and a graduate student, respectively, in nuclear engineering at MIT. The pair is developing a prototype x-ray mammogram system that will record information about absorption and refraction of the radiation as it passes through an object.
Refraction is a change in the direction of a wave as it passes from one medium to another; it's the same effect that makes a straw in a glass of water look broken.
"Cancers have very similar x-ray absorption to normal tissue," says Daniel Kopans, director of breast imaging at Massachusetts General Hospital, in Boston. But cancers may have different refractive properties. Kopans says that preliminary studies using a synchrotron accelerator have shown that cancers appear to refract x-rays differently than normal tissue does. If this is so, recording this information during an x-ray scan might indeed help doctors better delineate tumors.
Since the widespread adoption of mammogram screenings in the early 1990s, the breast-cancer death rate has gone down by 25 percent in the United States. But breast cancer is still the second leading cause of cancer death in women. These tumors remain particularly difficult to detect because breast tissue has a variable structure. Five millimeters is the limit of detection with conventional mammography, so doctors know that they are missing tumors, says Richard Moore, research director in the breast-imaging center at Mass General.
Moore says the hallmarks of breast cancer that doctors look for in mammograms reflect disease processes that have been under way for a long time: tiny calcifications that signal cancer-cell death, and healthy surrounding tissue that's pinched, like fabric. Although they don't know what they'll find, Moore says that Lanza's x-rays might provide new information about breast tumors that enable doctors to see disease sooner, before the calcifications and pinching effects visible in a conventional mammogram even develop.
It's practically impossible to measure how a sample refracts waves unless the waves all start out going in the same direction at the same frequency. Conventional x-ray tubes--such as those used in mammography--can't do this, and x-rays can't be focused with lenses and mirrors. One way to achieve the uniformity, or coherence, necessary for refraction measurements is to run the x-rays through a particle accelerator. But these are too large and expensive for hospital use.
Another way to make coherent radiation is to filter the waves generated by a conventional x-ray tube through a tiny hole in a lead shield. The rays come at the shield every which way, and they exit the hole in uniform circular waves. But because only a small proportion of the waves generated by the tube can squeeze through the hole, using this kind of filter takes a lot of power and generates a very weak image. In such a system, a patient would have to hold still and be scanned for a very long time, says Lanza.
The system Lanza and Damato are developing combines a traditional x-ray tube with a filter that has hundreds of tiny holes for generating coherent beams of x-rays. First, these coherent waves pass through the sample. Next, the waves pass an interferometer, which collects information about how each of the hundreds of sets of waves was refracted by the sample. Then they pass to a traditional absorption detector, which collects information about how each of the hundreds of sets of waves was absorbed by the sample.
Hundreds of interference images are then combined with the hundreds of absorption images into a single picture that a radiologist can read. Berthold Horn, a member of MIT's computer-science and artificial-intelligence laboratory, is developing algorithms to process the x-ray images. "The computer becomes an integral part of the imaging system," he says.
Similar filters are used in x-ray astronomy, in which the objects of interest--the stars--are very, very far away. Horn and Lanza were the first to apply this technique, called coded-aperture imaging, to nearby objects. They have already employed it to improve the resolution of a gamma-ray imaging technique used on lab animals, and they believe they will see similar results with x-ray imaging.
