Speaking of Precision Blog
Previous in Blog: Closing the Loop- Post Job Continuous Improvement   Next in Blog: It’s Really About Time
Using Frequency of Occurrence to Find Root Cause
Posted November 09, 2012 10:17 AM by Milo
The frequency of occurrence of an unexpected characteristic or non-conformance is an important indication of possible root cause.
When you tie frequency of occurrence numbers back to the process you can gain some insight into what just may be the root cause.
"Occasionally I get one of these parts with the drill going off-center." While this sentence names the problem, it doesn't give us much insight as to where to look- the drill I guess.
"I have about half a percent of the parts exhibiting an off-center drill feature on my six spindle," gives us enough information to think that perhaps the first couple of inches of one bar on a stock up was crooked, resulting in the off-center drill.
If you can do the math, you can uncover the root cause.
Converting count to a percentage of production can help you prioritize where in your process to look for the likely cause.
Chemobabe the numbers girl.
Engineering Fields - Control Engineering - Control Engineering Technical Fields - Education - Industrial Training Engineering Fields - Manufacturing Engineering - Manufacturing Training Engineering Fields - Electrical Engineering - Electrical engineering Training Engineering Fields - Instrumentation Engineering - Instrumentation Engineering United States - Member - New Member Engineering Fields - Energy Engineering - Become part of the larger group, change your world.
Re: Using Frequency of Occurrence to Find Root Cause
11/10/2012 12:44 PM
Thought the viewers of this post would like to see comments on this at http://www.linkedin.com/groupItem?view=&gid=1850562&item=ANET%3AS%3A183363663
AB PLC Training onsite, On-Line, training software and more. BIN95.com
