Notes & Lines Blog
Notes & Lines
Previous in Blog: Theremins...and Beyond!   Next in Blog: Impossible Objects: Messing With Your Brain Since 1934
10 comments
Electronic Composer, Orchestral Conductor, Garage Scientist
Posted November 20, 2012 12:26 PM by Hannes
Pathfinder Tags: cancer research rife
Miracle cures! Blackmail and revenge! One single man threatening to overthrow the medical profession!
These might be some taglines for The Cure, an in-progress documentary about the work of Anthony G. Holland, a professor of music at Skidmore College in Saratoga Springs, NY. Holland is also an amateur scientist who has been running with a much-discussed idea that is steeped in mystery and often dismissed as quackery.
Royal Raymond Rife (1888-1971) is a central figure in this discussion. In the 1930s, Rife claimed to have discovered a "mortal oscillatory rate" for various pathogens, meaning that causing these organisms to vibrate at specific frequencies effectively destroys them. He went as far as inventing the "Rife machine", a simple electrical device which passes tiny amounts of current into a patient's skin. Rife himself further claimed that his work and findings were brought down and discredited by the American Medical Association, which he claimed was at the center of powerful conspiracies against him.
Royal R. Rife (left) with his Rife machine. Via RifeSecrets
Rife was largely forgotten until his work was revived by the 1987 book The Cancer Cure that Worked, which spawned numerous businesses marketing and promoting the "Rife machine", as well as dozens of medical fraud lawsuits.
Holland was intrigued by this research, enough to try to construct a Rife machine on his own. For over six years, Holland conducted experiments on pancreatic cancer and leukemia cells using a homebrew setup consisting of a simple frequency generator and several amplifiers. Holland claims that, while his initial experiments using a single signal were ineffective, by combining two frequencies to strengthen the high harmonics of one signal he was able to obliterate certain cells on certain frequencies. If this sounds familiar, it's similar to the principle that enables the human voice to shatter a glass. Although his early findings were marked with inconsistencies, Holland claims to have destroyed 90% of some pancreatic cancer samples using one signal.
Mr. Holland at his day job. Via The Saratogian
Anthony Holland conducted his experiments at Skidmore's biology department lab and at the lab of his former student Jonathan Brody, a scientist at Thomas Jefferson University in Philadelphia. Holland formed Novobiotronics, his own non-profit firm, in 2011 to continue his research, and has published data from various trials on his site.
While both Rife and Holland may both be dismissed as eccentric amateurs, this is a clear case of an accomplished musician's inspiration to dip into science. And who knows? He just might be onto something.
References:
This American Life - Mr. Holland's Opus (radio transcript)
The Cure Blog
Re: Electronic Composer, Orchestral Conductor, Garage Scientist
11/20/2012 10:21 PM
From the NPR broadcast, it seemed that adequate controls and replication are lacking. Nonetheless, success is to be wished for.
Good Answers: 54
11/21/2012 12:29 AM
Why are you giving more publicity to a crank?
Gullible sick people get sucked into this sort of rubbish and end up loosing their savings. Surely there are enough homeopathy, iridology, chiropractic, prayer and magic diets to got around already.
11/21/2012 10:43 AM
Did you miss the term "nonprofit"? Research does cost money, but no research means no progress!
While I certainly agree that one must be at least a little skeptical, as Wal pointed out, there are multiple reasons to have hope that this could be or lead to major progress in finding one or more new methods of reducing the impact of one or more forms of cancer.
It is absolutely clear that Western medicine does NOT currently have a handle on controlling Cancer, so something different MUST be tried.
03/05/2013 10:07 PM
Homepathy, chiropractic, and some of these things are nothing to be accounted of. I think it is dangerous to be experimenting with anything like this that might destroy cells. If it can destroy a bad cell it can destroy a good cell. How do you know what you are doing? However you are absolutely wrong in thinking that the run of the mill medical system has the benefits that people think it does. Diet, prayer and some of these things do work.
Good Answers: 102
11/21/2012 2:47 AM
Not magic. It is not totally outrageous to suspect that electromagnetic fields can have an effect on a living critter.
  • When working around high level RF fields a "sensation" is experienced. Its not a good sensation.
  • Microwave ovens work.
  • X-rays work.
  • Electro convulsive therapy kinda works.
  • How about acupuncture and the "twitch-o-matic" thing the therapist connects....
I wish these guys all the best even if they fail. At least somebody cares enough to explore the possibilities and make observations.
Reply Good Answer (Score 4)
11/21/2012 8:32 AM
Good response! Want a GA?
11/21/2012 10:33 AM
And where would the scientists (and cheesemakers) be if they decided:
"Mold is just mold."
11/21/2012 2:01 PM
R.R.Rife was a true genious. He invented a "dark field" microscope that was the first ever to allow viewing of viruses invading living cells. He used this to discover the critical frequencies that destroy capsids of specific cells (mostly pathogens).
Today, similar research is being conducted at Arizona State University Physics Department. It uses laser pulses rather than RF, which can penetrate water much more effectively. Here is a link to just one of many papers they have published:
http://spie.org/documents/newsroom/imported/0928/0928-2007-11-16.pdf
Good Answers: 32
11/22/2012 5:58 PM
Deja Vu all over again... :-) Some years ago I worked with electronic > resonant stimulation of plants and nitrogen fixing bacteria. Founded Biotronic Research, and have had access to some of R.R.Rife's machines including his famed microscope and have spent some time with one of his co-workers who explained some of Rife's theories and workings. Have, as well, met with others who are carrying on the work of Wilhelm Reich. Interesting times. Have seen some amazing, very real and repeatable results. Have seen a lot of greed as well which has derailed many, otherwise legit, research projects. Back to topic... Rhythm, resonance and waves, are at the heart of it all, no? Do it right the one way, it's music to plants and animals, they'll prosper. Do it right the other, crystals will crack and viral bodies will fracture. Spinning an atom, swinging a bridge or making someone smile, induced resonance... It's not all quackery.
11/27/2012 8:19 AM
Viagra started off as a heart medication, yes? A cure might not be where you expect it to be. Or a solution to another problem might be found while you research your own. Keep an open mind.
dkwarner (1); ffej (1); IdeaSmith (1); jweller (1); kendall (1); Steve of the North (1); Tornado (1); Wal (1); WoodwardDL (1)
