Previous in Blog: A Day With NYC's Pothole Crew   Next in Blog: Autodesk and the Cloud, Part 1: Customers 'Absolutely' Will Have a Choice
14 comments
Kingston HyperX Predator USB Flash Drive Does the 1TB Dance
Posted January 10, 2013 10:00 AM
From Coolest Gadgets:
You know that SSDs are going to get a run for their money when the USB flash drive capacity has upped the ante by more than a mile. Case in point, CES 2013 saw the introduction of the Kingston HyperX Predator that weighs in at 1TB of storage space.
Re: Kingston HyperX Predator USB Flash Drive Does the 1TB Dance
01/10/2013 1:25 PM
I wanted one until calculated cost per bit.
I just bought a 16 GB thumbdrive for $9 USD.
A 1 TB drive has 62.5 times more storage capacity then the one I just bought and cost 333 times more. I just buy 62 more 16 GB drives and call it a day.
$3000 for a TB of storage on a thumbdrive is crazy. Do to thier small size and portability, these things get lost or broke. I would love to have that much storage in such a small package but I don't think it's worth the gamble.
Good Answers: 84
01/10/2013 9:13 PM
Was in Best Buy the other day and saw a 128 GiB Flash drive for $169. Eight of these would also give you 1 TiB but would set you back 'only' $1350+tax, and you would have only eight drives to manage versus 62 (I have enough trouble keeping track of my car keys as it is).
Possibly the best reason is the least obvious: you're not keeping all of your eggs in one, very expensive (for now) basket. Something to be said for distributing the risk of that across multiple drives.
01/11/2013 10:19 AM
You can get 1 tb for $70 external hd, 5" by 6" by 2"....paying over $1k is just crazy talk...
Good Answers: 84
01/11/2013 5:44 PM
True, you can buy capacious outboard hard-drives for next-to-nothing, and compact ones, too (I've got several myself), but the context here is one of flash drives.
01/13/2013 7:36 AM
Your sentence is slightly ambiguous,so just to be clear, when you wrote 'capacious' you were referring to the large amounts of storage available, right?
Your addition of 'and compact ones, too', makes me wonder if you instead intended to juxtapose 'capacious' with 'compact'.
I'm asking because I think of 'capacious' as 'roominess on the inside', and while many times something that qualifies as such would also be 'large on the outside', this case is one of the exceptions....
...OK, I realize that sounds super pedantic, but I'm really just curious about your intent and if your understanding of the word differs significantly from mine.
Good Answers: 84
01/13/2013 9:18 AM
Physically-small, high-capacity drives. One clear advantage flash drives have over other forms of outboard mass-storage is of course their diminutive size. Were this an announcement of 1 TB available in a standard HD form-factor, we'd think they were nuts. Not Old News; Prehistoric. What makes this 1 TB flash drive news is of course its large storage capacity AND its small size. How do we know it is small? Because it is a flash drive and all flash drives are small. They don't need to tell us because this knowledge is implicit in the technology itself. Mention a hard drive, however, and you've said nothing at all about the drive's physical size; it could be tiny or huge; you don't know. Where the context demands such knowledge, it must be explicitly stated in the case of hard drives unless supplied by other elements in the context. As the context is one of buying a less expensive, outboard hard drive with comparable specs, implicit in 'comparable specs' is the ideal of diminutive size, hence my use of "capacious AND compact" with the use of the word 'AND' as implicitly representing the explicitly-unifying *third* spec. :-))
01/15/2013 6:56 PM
OK.
I had just never seen capacious used as bulky instead of roomy.
Good Answers: 84
01/15/2013 7:51 PM
Not 'bulky' really; more a reference to 'abundant capacity,' however measured. 'However measured' is the key; 1 TB is certainly 'capacious' in terms of how many bytes you can store on the drive, whereas the drive itself occupies no more physical space than your little pinky (far less, actually, is occupied by the data themselves, given that the structure in which the data are stored is an ultrathin 'film' of trillions of integrated, nanoscale devices which together occupy only the top surface of several very thin, planar silicon crystals. Total volume consumed by this 'film' is maybe a couple of cubic millimeters at most. The drive is capacious on the one hand whilst, on the other, it is anything but. It's how you measure it! :-)
01/15/2013 8:04 PM
OK.
I misunderstood you twice... at least.
Good Answers: 84
01/15/2013 8:51 PM
Remember to get a second - and maybe a third - opinion. :-)))
United States - Member - New Member Hobbies - Automotive Performance - New Member
01/10/2013 1:39 PM
the cost will come down before you know it.
01/10/2013 1:45 PM
1 TB on a stick sounds good but even at typical USB 2.0 speeds it would take you most of a long day to load or unload the whole drive.
01/10/2013 2:34 PM
But it said it was USB 3.0, that means a theoretical "maximum" transmission speed of up to 5 Gbit/s (625 MB/s). If your computer does not have USB 3.0, I have seen cards for about $30 USD. Even at half that speed it won't take too long too fill it.
01/11/2013 10:23 AM
Its 1 K now. Think about how quickly those prices drop. The gigabyte standard will be gone in no time and replaced by TB.
Baxter (2); europium (5); JPool (2); SolarEagle (1); tcmtech (1); truth is not a compromise (3)
