Previous in Blog: Skydivers Miraculous Escape As Planes Collide   Next in Blog: What 3D Printing Can & Can't Do
3 comments
Lean Manufacturing Optimizes Everything
Posted November 05, 2013 9:59 AM
From Design News::
Manufacturing throughout the world is becoming leaner. That translates into less waste, less cost, less energy. It also means higher production and greater optimization. Anything that contributes to greater efficiency in production is now bundled into the concept of lean.
Re: Lean Manufacturing Optimizes Everything
11/05/2013 1:51 PM
Lean manufacturing is just like my PC.
It's fine when it's working, but if it crashes???????????????
11/06/2013 11:15 AM
In my experience, it's a Dilbert world. When Lean crashes it's almost always due to Management tampering with the system. Typical mistakes:
1) Insisting that a production line be run at maximum capacity, not maximum efficiency.
2) Insisting that inventory buffers are "too big" and cost "too much" even though historical data shows that smaller buffers cause shut-downs which are costlier.
3) Insisting that, since an optimized system is running without problems, there must be something that can be removed or changed to make it a little cheaper to run. (Usually via a request to increase capacity or to skip a scheduled maintenance or have one operator do the work of two)
4) Insisting that, after a crash, it's more important to just get the system running again than it is to find out the cause of the crash.
11/06/2013 12:48 PM
Absolutely!
