Networking & Communications Blog
The Networking & Communications Blog is the place for conversation and discussion about power & apps, wireless technology, voice & internet, and network security as they relate to networking and communications fields. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: What I Learned At Camp   Next in Blog: Rolling Out the Smart Home
Designing Green Data Centres
Posted November 22, 2013 12:00 AM by Drusilla Anderson
Typically a data centre utilises a lot of energy. After all, this is an area containing a wealth of different technological products. The servers themselves require a lot of power. However, you also have to consider the methods of cooling as well. Nonetheless, most data centre companies are doing their utmost in order to become more environmentally friendly. This is extremely important in the current day and age. If you are not seen to be doing your bit then your reputation can easily be hampered. Thus, to ensure this does not happen to you, read on to discover some great suggestions for making your data centre green.
One of the most important things to do is choose your method of cooling with great care. If you were to use air conditioning for example, you would be using one of the most energy zapping cooling methods. There are a number of good options at your disposal. Containment is considered the best route to go down. More and more companies are using cold aisle containment. As you may have gathered from the name; this separates the hot air from the cold in order to cool your servers efficiently. This requires a lot less energy in relation to the other options. It also boasts an array of other benefits too such as high performance, lowered costs and increased life expectancy of your servers. Going green definitely does not mean you have to compromise on quality.
In addition to this, another easy yet highly effective way of ensuring your data centre green is to make sure you block off all rack space that is not being used. This is imperative. It relates to all unused space - even the area in between the racks and the outer cabinet shells. Many companies ignore this simple suggestion and as a result they find that their data centre runs extremely inefficiently.
Aside from the two main points that have already been mentioned it is also highly advisable that you make sure of energy monitoring tools. How are you supposed to know if you are reducing your carbon footprint if you have absolutely no idea regarding the amount of energy you are using? In fact, they are extremely beneficial when it comes to the subject of temperature control in particular. They will be able to determine whether you are wasting any energy and they will also pick up on ways you can be more energy efficient as well. These monitoring tools are worth their weight in gold.
Finally, another area you should look at is power distribution, namely Uninterruptible Power Supplies (UPS). These are those that provide backup power to data centres. If you increase the efficiency of your UPS system you can make direct 24 hour a day energy savings. This is both in relations to indirect methods via reduced building transformer losses and lower heat loads as well as directly within the UPS itself.
There are different ways you can make your data centre more energy efficient. The options mentioned only scratch the surface of what you can do to make your data centre green. Don't underestimate how important this either, especially in the modern day!
Editor's Note: Drusilla Anderson is a freelance content writer who enjoys writing article and journals on technology solutions and all latest updates. In this article, she explains about the effective approaches for designing green data centres.
Re: Designing Green Data Centres
01/10/2014 11:25 AM
Seems like a mish-mash of energy savings, efficiency, power use, environmentalism, being green, etc.
This is like a regurgitation of the Schneider Energy University course overview.
Want to save energy? Turn off the servers, turn out the lights, open the transformer input main, and walk home.
common knowledge...less common than common sense
