Flexible honing tools
have a few nicknames. Although our surface finishing solutions are known by the trade name Flex-Hone, some users call our tools ball hones because
of their abrasive globules. Other users prefer names like grape hones, bead
hones, bottle brush hones, and even dingleberry hones.
Flex-Hone tools are
also called cylinder hones because they're used for
rebuilding car, truck, and motorcycle engines. When engine blocks are
manufactured, OEMs typically use large honing
machines to size the bores. These tools are suitable for material removal, but
it's difficult to match the controlled surface condition of the Flex-Hone for
engine rebuilds. The plateau finish that a BRM engine hone
imparts optimizes lubrication, reduces wear, and promotes piston ring seating
and sealing.
Cylinder Deglazing
Brush Tools
Over time, a piston's reciprocating movement polishes
cylinder walls or liners and prevents engine oil from adhering properly.
Instead of a uniformly-spaced series of grooves, the cylinder gets a "glaze"
that can cause engine problems. Left unbroken, this overly-smooth finish
impedes lubrication and increases friction. If the cylinder walls or liners are
polished to a mirror finish, the piston rings can't provide a tight enough
seal. This surface finishing problem affects diesel engines as well as
gasoline-powered ones.
For automotive
mechanics who rebuild engines then, cylinder wall deglazing is an important
task. For The Bug Boys, a blogger who describes engine
rebuilds and other automotive projects, the right tool for the job is the BRM
Flex-Hone. Although some engine mechanics refer to our cylinder hone as a glaze
breaker hone or a glaze buster hone, The Bug Boys writes about ball hones.
During a recent rebuild of a Saturn engine, for example, the blogger
explained that "I used a ball hone and it worked great."
How to Ball Hone a
Cylinder
Although some
manufacturers mount Flex-Hone tools in machine centers, hobbyists
like The Bug Boys typically use a handheld electric drill. Versatile and
easy-to use, BRM ball hones are self-centering, self-aligning to the bore, and
self-compensating for wear. These engine hones require the use of a lubricant
or honing oil, and should be inserted into the bore while the cylinder hone is
spinning. Recommended revolutions per minute (RPM) vary with the diameter of
the brush tool and the application.
As the Flex-Hone Resource Guide explains, BRM
ball hones are low RPM tools. We're not sure which size tool The Bug Boys used,
but its diameter was probably between 1/2" and 2" since he reported good
results at 1000 RPM. The mechanic also followed best practices by starting
slowly, increasing the RPMs, and then exiting the bore with the tool still
spinning. "I got better cross hatch marks and a cleaner cylinder," he
explained, adding that "your cross hatch marks should be about 45 degrees."
Finally, the engine
mechanic cleaned the newly-honed cylinders and lubricated them with motor oil.
As Flex-Hone users like Caterpillar know, the best way to clean a ball honed
cylinder is with warm or hot soapy water and a cylinder washing brush.
Lubrication is essential before installing the piston rings, which will now
seat properly because the cylinder walls are deglazed and the Flex-Hone tool has imparted an optimum surface finish.
