One of the problems facing the wide spread use of hydrogen as a fuel is the safe storage and transport of hydrogen.. While hydrogen has a relatively good energy to mass ratio its low density means that at atmospheric temperatures and pressures it takes up too much space to be a viable source of energy. However the volume can be reduced by storing it under high pressure or as a liquid at extremely low temperatures, but both of these methods consume considerable amounts of energy which makes them less efficient and they both have inherent dangers. A third possibility that shows potential is the use of hydrides as a storage medium.
Technically hydrate refers to a negative hydrogen anion that has two electrons thus filling the "s" shell. However, you will never find the negative hydrogen anion by itself but rather combined with some other element or compound, so the term hydride is normally used to describe compounds that contain hydrogen anions rather than the anion itself.
By filling a storage tank with something that will readily form a hydride, hydrogen can be stored without the problems associated with high pressures or low temperatures. The hydride can then, through methods that are dependent on the specific hydride, be released at a controlled rate for use as a fuel in either an internal combustion engine to create mechanical power or a fuel cell to create electrical power.
You can find more about the use of hydrides as a storage media for hydrogen from the following links.
The hydrogen or H2 molecule is extremely small and this makes containing it exceptionally difficult. No matter how well a container is sealed H2 will, over time leak and this is something that needs to be allowed for in any design. However, storing the hydrogen as a hydride means that it is bonded to other atoms and therefore not free to squeeze through the container walls as happens when H2 is stored in liquid or gaseous form. Hydrides do not completely eliminate the leakage of stored hydrogen but they can reduce it considerably.
No matter which method of hydrogen H2 storage is employed the process of storing the H2 consumes energy. If you compare the amount of energy expended in the storage process to the energy in the stored hydrogen you get typical figures of 30%-40% for compressed H2, up to 42% for liquid H2 and 12.5% for Metal hydrides
A factor that is often overlooked when calculating the efficiency of a fuel is the energy expended storing the fuel. Typically with fossil fuels this is relatively low, however, this is not the case with hydrogen. The amount of energy expended storing hydrogen varies from method to method, but if you compare the amount of energy expended in the storage process to the amount of energy in the stored hydrogen typical, figures are 30% to 40% for compressed gaseous hydrogen, 42% for liquid hydrogen and 12.5% for metal hydrides. While metal hydrides are clearly the most energy efficient storage method you are still losing one eighth of the energy being stored.
Clearly the use of hydrides to store hydrogen has numerous advantages over storage as H2 however there is one serious drawback with hydrides and that is the mass of the hydride when compared to the mass of hydrogen stored. With hydrocarbon fuels the mass of the tank is typically only a fraction of the mass of the fuel. With metal hydrides however the mass of the hydrogen to the mass of the hydride is typically 1.5% which means that to store 1 Kg of hydrogen you need around 67 Kg of storage medium.
Initially, the concept of replacing fossil fuels with hydrogen looks good, however, when you take into account the physical problems and inefficiencies of producing, transporting and storing hydrogen the concept becomes somewhat tarnished. None the less, these are technical problems and given the time and resources solutions are bound to be developed.
The use of hydrides to store hydrogen does show potential, however, it also raises questions. Is the mass of the hydride that is needed to store hydrogen acceptable, or will it make the overall efficiency too low to be practical? While hydrides are the most energy efficient of the primary storage technologies they still consume 12.5% of the energy being stored, so, are storage losses of this magnitude too great a loss to make the system viable? Some metal hydrides can react explosively with things like water so what about the safely of hydrides in the event of accidents and during emergencies?
