E&E Exchange Blog
E&E Exchange
Previous in Blog: Grow House Energy Concerns   Next in Blog: A Dark Side of Solar Power
5 comments
Half-Price Solar Power
Posted August 02, 2014 12:00 AM by Chelsey H
Solar power is still too expensive to be a mainstream source of power-but it is very effective and a new material could cut solar power costs in half.
Glint Photonics, a startup company funded by the Advanced Research Projects Agency for Energy (ARPA-E), has developed a new technology that maximizes a solar panel's potential to capture light.
The new material enhances the reflective properties of solar panels in order to capture light across a large span of different angles. Focusing the sunlight makes it possible to use smaller, cheaper solar cells. Image Credit
The new solar energy system has two parts. The first is an array of thin, inexpensive lenses that concentrate sunlight. The second is a sheet of glass that serves to concentrate that light more-up to 500 times-as light gathers over its surface.
On the front and back of the glass is a reflective material that traps light inside the glass. One of the sides features the new substance made by Glint. According to MIT review, "When a beam of concentrated light from the array of lenses hits the material, it heats up part of it, causing that part to stop being reflective, which in turn allows light to enter the glass sheet." The light bounces around until it reaches the solar cell mounted on the edge of the glass to generate electricity.
Panels currently on the market have a tracking system that ensures the panels are taking in the most amount of light possible. The panels change their reflectivity in response to heat from concentrated sunlight in a way that makes it possible to capture light coming in at different angles throughout the day. The tracking system requires lenses or mirrors, which must move precisely as the sun advances across the sky using heavy equipment to keep the apparatus steady. Without the need for a tracking system, the solar panels can be made at a much lower cost.
In the new system, the beam of light from the lenses moves and the material adapts, always allowing sunlight in only where the beam of light falls. This reduces the need for an apparatus that keeps the system pointed directly at the sun. Image Credit
According to Glint's CEO Peter Kozodoy, the solar power from its device could cost four cents per kilowatt-hour, compared to eight cents per kilowatt-hour for the best conventional solar panels.
There are still some challenges, but Glint received the first installment of grant money from ARPA-E this month to allow the company to scale up from prototypes to commercial scale.
Re: Half-Price Solar Power
08/03/2014 2:32 AM
Is ARPA-E this year's Solyndra? The "explanation" here seems confused.
08/03/2014 9:05 PM
I am sure such research can bring solar energy at the door step of a common man and efforts will harness maximium benefit to mankind. I wish to see that day when every individual howsoever down trodden will have a lighted house and will live a dignified life.
Good luck sir.
08/03/2014 9:21 PM
Very big claims of 4c/kWh in what really is a saturated R&D field.
I couldn't find any figures for this proof of concept device, and Glint Photonics (which appears to have one its first back in 2012) has some patents, only 3 employees and no products or income except through awards and grants.
Hmmmm.
08/04/2014 6:56 AM
Is there a way to check out political donations of this company, this may actually be the driving force of this company's income.
08/04/2014 4:00 PM
Well this is what I found after a quick search......
http://sbirsource.com/sbir/firms/12203-glint-photonics-inc
Balraj Seth (1); jack of all trades (2); phoenix911 (1); Tornado (1)
