Physics In Film Blog
Physics In Film
Movies and TV shows, when done right, are great ways to entertain and tell stories. They can be fascinating avenues for experiencing some phenomena we may never actually witness in real life. They can also be ridiculous or laughably awful when scientific liberties are taken a bit too far. Join the CR4 team here in the Physics in Film blog as we explore the good, the bad, and the ugly of the science and engineering we see on the screen.
Previous in Blog: Medieval Physics - Bows & Arrows   Next in Blog: Medieval Physics - Siege Engines
8 comments
Medieval Physics - Jousting
Posted August 26, 2014 12:00 AM by cheme_wordsmithy
In a previous blog entry, I gave a short summary of the physics and history of the bow and arrow (thanks to all you CR4 users who shared your insight and knowledge on the subject). Today I'd like to delve a little bit into the "Sport of Kings": jousting.
The most vivid picture I have of jousting is from the movie A Knight's Tale, in which a squire (Heath Ledger) takes up the sport in order to "change his stars" and become a knight. Jousting was (and still is) a sport involving a horse, a rider (knight), and a lance (the knight's weapon). In jousting competitions, two knights would draw their lances, ride at each other, and attempt to knock the other off their horse. In earlier (more brutal) versions of jousting, hand-to-hand combat often followed, the objective being to incapacitate the opponent in order to win his horse and equipment.
The sport of jousting came about as a result of the popularity of the lance in medieval warfare. The combat lance was the primary weapon used by mounted soldiers, especially those leading a charge. It is a long spear-like weapon, ranging from 9 to 15 feet in length. It was made of wood, with a metal (typically iron or steel) tip on the end. Its shape and length made it unsuitable for throwing or repeated thrusting, but was instead an impact weapon meant to utilize the force of the horse and rider. The circular handguard on the lance (called a vamplate) was meant to keep the rider's hand from sliding upon impact.
In this spirit of combat, the joust was a show of a knight's ability to utilize his lance to transfer his and his horse's momentum into his opponent, all while deflecting the blow of his opponent to remain on his horse. The knight who could break more lances on his opponent (i.e. score more points) and/or dehorse him was the victor. To reduce the chance of death or severe injury, lances used in the jousting sport were made with coronals (crown shaped metal caps with three blunted prongs) instead of metal blades. The prongs allowed the lance to more easily catch the knight's shield or armor.
So how much force was a jouster actually able to generate through his lance? One might think that a simple force equation of mass times acceleration (F=ma) would suffice. Sure, it is true that a larger knight with heavier armor and a bigger and faster horse with be able to generate more momentum and force. Unfortunately, this generic force equation is an oversimplification that incorporates some faulty assumptions, the first being that the lance, knight, and horse are all one mass. This is not true, as the lance is held by the rider's hand/arm which is connected to the rider's torso, which is connected to the rider's lower body, which is on top of the horse. All of these are separate pieces which have the potential to move and give upon impact and reduce the force from and to the riders. Thus it is the skill of the knight that determines how effectively he can incorporate all of these parts together to generate more force.
Another misplaced assumption is that all the force in the equation translates to the tip of lance. In reality, other factors will reduce the force of the blow, such as the lance's point of attack (i.e. if the opponent is not directly in line with the rider's acceleration, the lance will be hitting at an angle). Also, any deflection of the lance off the opponent's armor will reduce the force of the blow. Because the upper and lower and lower body can move separately (the torso can rotate left and right), a knight that deflects will experience torque when hit more than a force that pushes him backward off the saddle.
Ultimately, the true limiting factor on force is the strength of the lance. Because the lance is made of wood, the lance will often break and shatter from a good hit. Thus the strength of the lance is a limit on the maximum force that can be transferred to the victim's body from the hit.
There are other factors to consider as well, such as return force. Assuming the lance is well gripped or attached to the knight, the knight must be ready to resist the return force generated when hitting his opponent, else he be dehorsed himself. Also, since both knights will be armed in the contest, there is added complexity of who hits first and what movement occurs in between hits.
Obviously this is not an exhaustive analysis, and I don't have any numbers on what forces generated by jousters would actually be (any takers?). Safe to say, if it's enough force to cause severe injury and knock a heavily armored man off his horse, it's quite a bit of force! Because of this, jousting today has moved away from direct physical combat to a skill sport of hitting targets and catching rings. In 1962, this evolved form of jousting was made the official sport of the state of Maryland, and it is still alive and well today.
Other sources
myarmoury.com
Lordsandladies.org
Re: Medieval Physics - Jousting
08/26/2014 1:04 AM
I always heard the "Sport of Kings" was horse racing....I think the true sport of kings is empire building....I personally find it hard to believe any king would risk his life in such a foolhardy endeavor, unless of course he was drunk out of his mind, which then seems more probable....I would say the modern equivalent activity that most closely equates to jousting, would be automobile racing, but with no first hand knowledge of jousting, it's just speculation....I think it would be more interesting to imagine how one might tip the odds in one's favor via lance design....and I would definitely add a face shield, and possibly a shotgun tipped lance....I would be known as the Black Knight of Thunder....lol
08/26/2014 7:36 AM
Perhaps it's called the Sport of Kings, not because the Kings engage in it themselves, but it's what kings spend time watching.
J B
08/27/2014 9:24 AM
Exactly, just like baseball is the All-American Sport, even though it is not played by ALL Ameicans.
Sport of Kings sounds better than the Royal Pastime. Makes the kings sound less lazy.
08/27/2014 9:43 AM
I did go to a Renaissance faire in Colorado Springs about 10 years ago, probably more than 10 years. I did enjoy it. Loved the turkey legs.
Anyways, If the "Sport of Kings" aka jousting, had the attorneys and players unions back then like they do now. They be playing flag football.
08/27/2014 8:15 PM
They have a big Ren Fest here in the Baltimore area, including jousting. The horses they ride are HUGE. As well as the tracts of land.
Lines were too long at the turkey leg stand so I didn't get one, but I heard they were good.
It is an interesting experience.
08/28/2014 6:57 AM
I agree, These Medieval Festivals in Northeast Wisconsin are getting Popular. In Port Washington, north of Milwaukee the have a well established one, and In Sturgeon Bay, (Wisconsin Penisula) they just had their first annual one but I missed it.
The horses had to be big to carry the armor, but they weren't draft horses, maybe later they became one. I once thought they were Percherons, Of all the draft horse they were the most elegant.... probably from the arab bloodline.
08/29/2014 4:36 PM
"Lines were too long at the turkey leg stand so I didn't get one, but I heard they were good."
Same here, but I just don't like the taste of dark meat, I much more prefer white meat on a bird.
Guess I'm more of a breast man than a leg man.
-ending the post now before anyone calls me on the innuendo-
08/29/2014 6:17 PM
Talking about innuendo, I can't recall....Isn't there a saying about once you tried dark meat..... Shoot, I forgot the rest....
adreasler (2); Brave Sir Robin (1); JBTardis (1); phoenix911 (3); SolarEagle (1)
