Previous in Blog: Efficient Battery Relies on Radiolysis   Next in Blog: Dishing Out Affordable Solar Power and Heat
4 comments
Wyoming Wind and Utah Storage Light Up LA
Posted October 31, 2014 12:00 AM by Engineering360 eNewsletter
What do you get when you combine a 2100 MW Wyoming wind farm, billions of cubic feet of compressed air energy storage in Utah, and an existing transmission network across southern California? The answer is an $8 billion renewable energy project that will fill a significant piece of Los Angeles's electricity needs. Clean Technia reports on this partnership of wind farm operators, compressor companies, transmission networks, and a financial arm tasked with some monumental fund-raising work.
Editor's Note: This news brief was brought to you by the Wire & Cable Technology eNewsletter. Subscribe today to have content like this delivered to your inbox
Re: Wyoming Wind and Utah Storage Light Up LA
11/03/2014 9:51 AM
A lot of hot air that cools down when stored and very poor energy efficiency.
11/03/2014 4:35 PM
Sounds like Washington, D.C., alright.
11/03/2014 5:33 PM
Yes, the secret to efficient energy storage with compressed air is to conserve heat. That's straight forward engineering. Use a huge pressure vessel, or insulate it, or use phase change materials to reduce temperature gradients. For example, if the hot compressed air is used to make steam, and the steam is stored in insulated vessels, the steam can be used to reheat the air before it is expanded, improving overall efficientcy.
11/03/2014 6:00 PM
www.isentropic.co.uk has the correct answer, and does not require underground caverns, but they do run their compressors hot for a reason, and have pressure vessels at some interestingly high temperatures, and one vessel with parts at a really cold temperature.
Brave Sir Robin (1); eriktheviking (1); James Stewart (2)
