Roger's Equations Blog
Roger's Equations
Previous in Blog: New Steel Alloy Stronger Than Titanium   Next in Blog: Off The Grid: Tesla's Home Battery
8 comments
Golden Ratio Variable Stars
Posted February 11, 2015 8:00 AM by Bayes
I came across an article on Scientific American about variable pulsars whose frequencies vary according to the Golden Ratio. I figured I'd post it here.
Here's a quick tutorial on the Golden Ratio if you're curious
Strange Stars Pulsate According to the "Golden Ratio"
Scholars have seen the golden ratio in nautilus shells, the Parthenon, da Vinci paintings and now in stars. A new study of variable stars observed by the Kepler space telescope found four stars that pulsate at frequencies whose ratio is near the irrational number 0.61803398875, known as the Greek letter phi, or the golden ratio (which is also sometimes referred to as the inverse of that number, 1.61803398875…). The golden ratio had not turned up in the celestial sphere before astronomer John Linder of The College of Wooster in Ohio and his colleagues analyzed the Kepler data.
The researchers looked at a class of stars called RR Lyrae that are known for their variability. Unlike the sun, which shines at a near constant brightness (a good thing for life on Earth!), these stars brighten and dim as their atmospheres expand and contract due to periodic pressure changes. Each star pulses with a primary frequency and also shows smaller brightness fluctuations occurring on a secondary frequency. The ratios between these two frequencies "are very important," says astronomer Róbert Szabó of the Konkoly Observatory in Hungary, who was not involved in the study, "because they are characterized by the inner structure of stars-and if a star exhibits many modes, then observation of the frequencies gives very strict constraints to stellar models." For four of the six RR Lyrae stars the researchers analyzed, the ratio of the primary to secondary frequencies was near the golden mean-within 2 percent of its value in the case of the star KIC 5520878, for example.
Article continues here
Re: Golden Ratio Variable Stars
02/11/2015 8:20 AM
The ratio between miles and kilometers is within 0.6% of the golden ratio.
02/11/2015 12:59 PM
I am not surprised with this finding at all, the golden ratio appears throughout science and nature abundantly.
I try to use in designing aesthetics for cabinets, enclosures, etc. There is just something naturally appealing about a machine cabinet proportional to the golden ratio.
I usually use the expression: (1+SQRT(5))/2
It is always on my mind even for ratio of sheaves, gears, shaft speeds etc.. I use it when I can.
Good Answers: 26
02/11/2015 3:07 PM
The pipe pig in my avatar picture is based on the golden ratio.
02/12/2015 12:33 AM
Getting an irrational number to be a gear ratio is a cute trick.
02/11/2015 2:53 PM
http://www.scientificamerican.com/article/celestial-sunscreen-dims/?mobileFormat=false
Celestial Sunscreen Dims Stars
March 11, 2002 |By Sarah Graham
Images: DAVID AGUILAR, HARVARD-SMITHSONIAN CENTER FOR ASTROPHYSICS
"Scientists have discovered why some stars dim and seem to temporarily disappear, a new study suggests. According to a report to be published in the April 1 issue of the Astrophysical Journal,..."
The April 1 date sounds warning bells, No?
02/12/2015 9:18 AM
Good Point Tornado but what I mean by "I use it when I can" means if I need two shafts rotating at different speeds for a shredding or grinding operation and if I had one gear with 24 teeth, If I could, I would try to be close to 39 or 15 teeth for the second gear.
02/12/2015 9:29 AM
There are analogous reasons for meshing components to be relatively prime to each other, so that every tooth/lobe on one contacts every tooth/lobe on the other.
02/12/2015 9:42 AM
True but, if two gears have the same PA and DP they should mesh fine. The number of teeth changes the OD which changes the shaft center distance and rpms respectively.
If I was building a watch I would be more concerned about the GCD of tooth ratios close to 1 but there are so many applications in gears when this is not considered such as two spur gears exactly the same, one on each shaft with one shaft driven and the other shaft driving....etc.
Regardless of gear ratios: the golden ratio is really cool.
Massey (3); Rixter (2); texasron (1); Tornado (2)
