Plant & Facilities Engineering Blog
The Plant & Facilities Engineering Blog is the place for conversation and discussion about mechanical and electrical systems, automation and instrumentation, maintenance and management, and products & services as they relate to plant and facilities operation. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: How to Turn Internet of Things into Reality   Next in Blog: Global Corrosion Costs Reach $2.5 Trillion Annually
Revised Standard for Rotating Electrical Equipment Repair
Posted March 26, 2016 12:00 AM by Engineering360 eNewsletter
The Electrical Apparatus Service Association (EASA) has updated its Recommended Practice for the Repair of Rotating Electrical Apparatus. The update replaces the existing standard that had been in place since 2010 and features 90 important changes. Among them are updated evaluation criteria for bearing insulation testing and the requirement to perform previously optional tests for winding resistance, insulation, and surge on every repair. It also includes revised unfiltered vibration limits to conform to current current NEMA and IEC standards values.
Editor's Note: This news brief was brought to you by the Plant & Facilities Engineering eNewsletter. Subscribe today to have content like this delivered to your inbox.
Good Answers: 25
Re: Revised Standard for Rotating Electrical Equipment Repair
03/27/2016 7:48 AM
It is observed that after rewinding motors performance is not as good as it was before rewinding. I suggest that rewound motors should be tested to important routine tests such as insulation, high voltage, temp. rise, noise, vibration etc.
