Previous in Blog: Fluorosilicone Gaskets for Pharmaceutical Equipment   Next in Blog: RoHS Compliance and Rubber Products
Fiberglass Gaskets for High-Temperature Sealing and Insulation
Posted May 17, 2016 4:55 PM by Doug Sharpe
Furnaces, boilers, stoves, vehicles, and lighting all have something in common. They require high-temperature gaskets for sealing and insulation. Typically, these heat-resistant gaskets are part of a larger assembly or system. For example, a gas furnace may contain heat exchangers made of metal plates and high-temperature gaskets. A variable-speed blower creates a vacuum, induces a draft, and forces hot air past the primary and secondary heat exchangers, which transfer heat between two fluids. The heat exchanger gaskets aren't the only components in this complex system, but they play an important role.
For engineers, choosing the right materials for heat-resistant gaskets is an essential design consideration. It's also important to select gasket materials with the right environmental resistance, but without "over-engineering" the part based on actual service temperatures. As an experienced gasket fabricator, Elasto Proxy can recommend the right rubber or non-rubber material for your high-temperature application. Using water jet cutting, we convert gasket materials cost-effectively without metal dies or tooling charges. Our skilled production personnel perform gasket bonding or joining operations with precision.
Material Selection and Heat Exchanger Gaskets
The heat exchanger gaskets used in gas-fired furnaces illustrate the importance of material selection. Unlike older heating systems, today's high-efficiency furnaces burn fuel near the top of the unit. The heated air is drawn downwards and unwanted byproducts from the combustion process are contained and then vented outside. Carbon monoxide can be deadly, and odors from combustion are unpleasant. There are other considerations as well. For gas furnaces with 94% or 96% efficiency, residual heat is minimal. This means that gaskets used near vents don't require high-temperature materials.
Near the top of the furnace, however, temperatures are much hotter. In fact, some combustion temperatures can reach 850° F. That's much too hot for people's safety or comfort, so heated air is drawn downward and cooled as it passes through a series of progressively-narrower metal tubes. This heated air also travels through a primary heat exchanger near the top of the furnace, and then through a secondary heat exchanger near the exhaust fan. To support proper heat exchanger operations, gasket materials that resist specific temperature ranges are required.
Fiberglass Gaskets vs. Silicone Gaskets
For engineers, understanding the differences in furnace temperatures can also help contain project costs. As a rule, gasket materials that withstand higher temperatures are more expensive. Silicones are synthetic elastomers that resist temperatures as high as 500° F. Fiberglass is a reinforced plastic that contains woven glass filaments and resists temperatures as high as 1200° F. This makes fiberglass a good choice for the gaskets used with primary heat exchangers. Yet fiberglass may not be necessary for secondary heat exchanger gaskets, where temperatures are significantly less.
Often, the gaskets for secondary heat exchangers can use less-expensive silicone instead. EPDM and NBR rubber may also be appropriate choices, but PVC plastic isn't because this plastic can emit unpleasant odors when exposed to heat. For engineers, it's also important to remember that heat exchanger gaskets may need to be made of materials that meet UL 94 requirements for flame resistance. High-temperature gaskets for other applications may need to meet other industry guidelines or regulatory requirements.
How Can We Help You?
Do you need high-temperature gaskets for furnaces, boilers, stoves, vehicles, or lighting? By working with Elasto Proxy, you can meet all of your application requirements - including cost-effective custom fabrication. How can we help you? From water jet cutting to manual secondary operations, we combine state-of-the-art technology with traditional pride-in-craftsmanship. To learn more, contact Elasto Proxy.
