Previous in Blog: Door Seal Design Guide: Six Things You Need to Know   Next in Blog: Window Gaskets: Design and Installation
Why Rubber Gaskets Fail
Posted June 06, 2020 11:56 AM by Doug Sharpe
Rubber gaskets fail for a variety of reasons. MTAP, an acronym that helps engineers design better gaskets, explains four common causes of gasket failure. If you want better rubber seals, design them with media (M), temperature (T), application (A), and pressure (P) in mind. Otherwise, you risk sealing failures that can have expensive, inconvenient, dangerous, or even tragic consequences.
Learn More
