Hemmings Motor News Blog Blog
Previous in Blog: EPA Proposes Further Increases in Ethanol Amounts, Wider E15 Distribution   Next in Blog: The 2016 Race of Gentlemen East: Two Days of Sand, Sun and Speed
10 comments
From the Toolbox #7
Posted June 06, 2016 10:00 AM by dstrohl
Pathfinder Tags: toolbox Tools what is it
This week's stumper is a pair of specialty pliers designed for a specific purpose. It performs a function that is seldom necessary today.
Initially looking like 6-1/2 inch snap ring pliers, this tool has slotted jaws instead of the normal clamps that would hold interchangeable points for snap rings. The slotted jaws are intentionally skewed at 90 degrees to each other in order to hold or pinch something very thin in diameter when pinched together.
Behind the jaws is a stud with a ball on the end that retains the removable t-handle that comes with the tool. The t-handle is key here: It pivots 360 degrees on the shaft and the bottom of the t-handle near the pliers has a raised step about ¼ of the way around its base. The t-handle, when installed on the shaft, leaves ¼ of an inch at its base, which lines up correctly with the opening on the jaws when the tool is compressed.
The pliers' action is very compact; the handles only move ¾-inch from fully closed to open. I have used this tool several times before and it works well, but it is one of those tools you absolutely need for certain jobs that later collects dust waiting for another classic car or motorcycle or lawn mower project to come along again. It was manufactured by the KD Tool Company in the USA and has a patent number on it as well.
More pictures and the answer on Hemmings Daily.
Re: From the Toolbox #7
06/06/2016 10:43 AM
Something to do with setting the points?
06/06/2016 12:54 PM
Yeah, that was my guess. or castrating meercats
06/06/2016 10:42 PM
Piston Ring Installer, I think. But I can't tell for sure. I looks like the tool for expanding them so they'll slide down the circumference of the piston, and can then be released into the ring groove.
06/06/2016 11:13 PM
Looks like a spring stretcher to me.
It would hold the spring in a stretched position while it was installed into place.
Good Answers: 54
06/07/2016 2:38 AM
Drum brake spring tool???
06/07/2016 3:12 AM
For fitting a throttle cable to carburetor slide type. ( mostly spring loaded)
To Carve a lion from a block of stone just chop away the part thats not the lion
Good Answers: 225
06/07/2016 5:10 AM
I had a pair of those once, don't know where they went.
They are called cable coilers, used for shaping the end of solid core cables for all sorts of things like your lawn mower throttle cable, heater controls etc.
The plier part holds the wire firmly while the T handle shapes the wire into a tight helix, the height of which is dependent on how many times you turn the key. The key rises up the post as the coil progresses.
You can see a small pin located adjacent to the coil forming post for the purpose of bending the wire so that the coil is central to the core of the sheath, this is done once the coil has been formed.
06/07/2016 10:09 PM
06/07/2016 6:49 AM
I'm guessing.The T bar bit holds something like a nipple on the end of a (heavy) spring return cable cable, and when turned, pulls the cable to the desired position, (against spring tension) at which point the pliers grip the cable to hold it in place whilst some other action is taken.
Like in my old motor bike days trying to put the clutch cable nipple back in the slot in the hand grip.
06/07/2016 8:19 AM
That would be handy, and could be used today.
andre pretorius (1); Autobroker (1); horace40 (1); JohnDG (1); LongintheTooth (1); micahd02 (1); phoenix911 (1); SolarEagle (1); spades (1); user-deleted-1105 (1)
