Aerospace Blog Blog
Aerospace Blog
Previous in Blog: Airbus Eyes Autonomous Aircraft   Next in Blog: EPA to Propose Emission Limits for Aircraft
4 comments
Could Mass-actuated Control Change Aircraft Design?
Posted September 13, 2016 12:00 AM by Engineering360 eNewsletter
A recent graduate of the aerospace engineering program at the University of Texas has flight tested a UAV that uses moving weights in its wings instead of traditional control surfaces or ailerons to turn. The test could prove important in designing future aircraft, as it would potentially allow engineers to eliminate ailerons and elevators, which increase drag. Eliminating ailerons and elevators could also reduce a stealth plane's radar signature.
Editor's Note: This news brief was brought to you by the Aerospace Technology eNewsletter. Subscribe today to have content like this delivered to your inbox
Re: Could Mass-actuated Control Change Aircraft Design?
09/14/2016 12:48 PM
The link appears to be broken.
Interesting concept. It's the method used to control hang gliders.
I'm wondering how much weight and movement would be required to control a full size aircraft, and I'm wondering how quick the response would be. For example, an airplane in a banked turn would require moving the weight uphill to level out (assuming it's inside of the wing), and move farther than in level flight to achieve the same moment.
And extra weight does have a drag penalty, depending on the lift to drag ratio. Extra weight requires extra lift. Extra lift means extra drag.
I'm guessing that it's been considered before and it isn't done that way because control surfaces are more efficient.
09/14/2016 4:17 PM
My thoughts exactly. But I have no longer been surprised by useless/impractical/uneconomical/absurd theses that come out of academia because of academia's penchant for 'novel' research. All the smart ideas have been presented so students are left to do dissertations on stupid ideas.
09/15/2016 10:15 AM
Don't forget that typically the school owns the dissertation rights, not the student.
09/16/2016 1:48 PM
Dissertations are not patents, but usually patents flow from dissertations.
Brave Sir Robin (1); James Stewart (1); redfred (1); Rixter (1)
