The incineration of garbage and waste was once a very common occurrence, however, it has to a great degree fallen out of favour due to the air pollution it creates and in many locations has been legislated out of existence. Initially one might think that the burning of garbage would only compound the problem with green house gasses, but like anything you need to look at the problem as a whole and there are several mitigating factors:
- Biological Waste: Much of the household rubbish and garbage is made up of biological matter and the hydrocarbons in such material are CO2 neutral as the carbon they contain comes primarily from the atmosphere. Materials like plant matter, paper, cardboard, meat products etcetera all contain carbon that has primarily come from the atmosphere.
- Decomposition Byproducts: If garbage or rubbish that contains biological material is used in landfill the decomposition of this material releases gasses like methane. Methane and similar gasses are far more detrimental to the atmosphere than CO2.
It is also not as simple as just burning the waste and using the energy to either produce steam or hot water for heating use or generate some other form of useable energy. Unless the rubbish is sorted prior to incineration there is the risk that the process will release toxins and pollutants like SO2, NOX, CO, HCl, dioxin, mercury, lead, cadmium, chromium, etcetera. While it is possible to add scrubbers and other treatment of the resultant products of combustion, they are not 100% efficient and the remaining ash will almost certainly contain similar toxins and pollutants.
The best way to minimize the risk and problems associated with toxic products of combustion is to remove anything that contains them prior to combustion and this makes the process less economically viable.
Another problem is the regulation and monitoring of the incineration process. The use of centralized incineration plants minimizes, reduces the cost of and simplifies the removal and monitoring of hazardous products of combustion but it increases the cost of collecting and transporting the garbage and distribution of the resultant energy. On the other hand a distributed system that incinerated the material close to the source reduces the transport and distribution costs but increases the cost of plant and equipment and makes it considerably more difficult to monitor and make sure toxins are not being released into biosphere either from the incineration process or the disposal of the waste.
The following links were used as the background for this thread and while some are fairly detailed they do present a good overview of the pros and cons involved in recovering energy from garbage.
With the population of the Earth steadily growing and the raising of living standards in underdeveloped countries it is clear that we cannot carry on with our wasteful ways. Not only must we reduce the amount of waste generated and recycle more but the recovery of the energy in the waste could have a real effect on the release of green house gasses. However, there is a considerable amount of disinformation being circulated by both proponents and opponents alike.. It is critical that not only the engineers, companies and society in general but legislators and governments look at all the factors and make decisions based on logic rather than emotive responses. Poorly thought through legislation can not only result in creating undesirable results but can often destroy the ideas and technology we are actually seeking.
Going back 40 years in the area I lived it was common for people living in medium to high density housing to incinerate almost all their rubbish and garbage leaving only the ash to be collected and disposed of in landfill. This has now been stopped by legislation and as a result trying to get an environmentally sustainable garbage incineration energy recovery system operational is pretty much an impossibility..
What are your experiences, are the EU legislators correct or have they got it completely wrong? Which is the best solution, the centralized incineration of garbage and the distribution of energy or a distributed local system that incinerates the garbage where the energy can be directly used? Can we really build garbage incineration systems that can eliminate the highly toxic pollutants that come from burning much of today's waste?
