Hemmings Motor News Blog Blog
Previous in Blog: Poll: Which Galaxie – Far, Far Away?   Next in Blog: Open Diff: Has Driving Become Joyless?
2 comments
How to Change a Tire. The Hard Way.
Posted May 16, 2019 9:00 AM by dstrohl
Pathfinder Tags: classic auto repair Tire
Neat setup, right? Not with those matching front and rear tires, it’s not! This just will not stand…If you’ve been following along with Hemmings’ digital content and stories, you may have spied a particular brown-sugar “dentside” Ford pickup truck making an appearance here and there. As the arbiters of all things Hemmings Green, we’re expected to not only know a few things about old cars, but, y’know, own at least one and maybe even drive one, on occasion. And so it is with this 1974 Ford F-350 Super Camper Special: it’s (mostly) a daily driver and it’s (definitely) hauled its fair share of Hemmings employees, stories, and adventures on the West Coast over the last few years.
This truck was born at the long-gone Ford plant in San Jose, California, back in the Spring of ’74 and lived its entire life in the shadows of that plant till about a decade ago when it finally moved a whole 50 miles north to San Francisco. The great thing about this guy is that it falls under the cutoff for the dreaded California smog check. The bad thing is that its carbureted 460-cu.in. displacement V-8 gets 6 mpg parked overnight and California is in its spendy summer blend fuel season — mix that with a roughly 40-gallon capacity among two tanks and periodically winning the Powerball is definitely a requirement for driving it on the regular.
The lengths a car nut will go for the right parts...
Re: How to Change a Tire. The Hard Way.
05/17/2019 12:53 AM
Every vehicle has it's, own special requirements.
05/20/2019 6:18 PM
Can’t top that story.
Just wanted to mention that my gf’s Camry had a leak in a tire recently. Fairly new tire. Took it to the (reputable) shop where she bought the tires and where they’ll fix a leak for free - only to find out the shop changed hands, and the place was nearly empty.
So I stopped at Walmart and bought the fixit kit for radial tires - which I’ve done before - and drove home to fix the tire.
Fun. When they installed the tires the lug nut air wrench must have been set to a gazillion for torque.
Luckily for me the long black iron pipe I bought just for this was near at hand. I slid the 6-foot pipe over the end of the Camry lug wrench, and with gentle pressure I was able to loosen the lug nuts and get the tire off.
A few minutes work with the tire patch kit, (a small nail caused the leak) remount the tire, and a half hour later, holding air and as good as new. (And yes, those radial plugs are fine at freeway speed.)
