The Engineer's Notebook Blog
Previous in Blog: Beer Thief Nabbed with Help from Facial Recognition Tech...and Woody Harrelson   Next in Blog: Using AI to Name Kittens
19 comments
Could a Robot Perform Your Next Colonoscopy?
Posted June 08, 2019 12:00 AM by M-ReeD
Pathfinder Tags: colonoscopy robot
Considering all of the unpleasantness surrounding the colonoscopy process — the preparation, the aftermath, the audience — researchers from CU Boulder are attempting to alleviate at least some of the discomfort.
A team of researchers, led by engineer and associate professor in the Department of Mechanical Engineering Mark Rentschler, has built a C-battery-sized robot that can travel through the unpredictable colon. The robot, called Endoculous, is designed to move throughout the body on motorized treads, in search of irregularities. It is also capable of taking biopsies when irregularities are detected.
Although the robot is far from ready to be tested in actual humans, in demonstrations using a pink plastic tube meant to mimic both the size and shape of the colon, the robot moves through the tube almost effortlessly, equipped with a camera, an air pump for inflating the colon, a water pump for flushing it and a tool port for housing biopsy snares.
Although similar technologies do exist, such as pill-sized cameras that can be swallowed, offering patients a view inside their bodies, what will likely set the CU Boulder robot apart is that it is capable of stopping and swiveling around.
“For our robots to be able to reach those regions that you reach with a pill-cam but also be able to stop and look around — that could be a big paradigm shift in the way we view these procedures,” said Micah Prendergast, a graduate student in Rentschler’s group.
Hoping to change how colonoscopies are done in the future, the CU Boulder team is also exploring how to minimize the human role in Endoculus, making it possible for the robot to navigate the intestines, and locate and biopsy polyps, all without a doctor present.
Welcome news for anyone who has ever run into their gastroenterologist while shopping for socks at Target.
Source: Glenn Asakawa/CU Boulder
Re: Could a Robot Perform Your Next Colonoscopy?
06/08/2019 10:26 AM
I think the "creep factor" is just as bad with this thing crawling around your insides.
06/08/2019 12:35 PM
Now bend over....
06/08/2019 8:42 PM
"Dr Kildare, Mayo Clinic, we have a proble-e-e-e-e-e-e-e-m."
06/09/2019 10:44 AM
" moon river "
06/09/2019 11:15 PM
As one who has had several colonoscopies due to age and Crohn's disease, the description sounds like it does not eleminate the clean-out-the-colon before the scope is done. For me that was the most bothersome part of the test. By far the most bothersome! The test itself was nothing since it was done under anesthesia. The audience was not bothersome since it was only the medical team.
Lehman57
06/10/2019 5:33 AM
Elon Musk says they're going to build this into the next gen Tesla.
My aspect ratio is 2.28.
06/10/2019 11:08 AM
Sounds more suited to his Hyperlooptm! (or hyperpoop!)
06/10/2019 6:23 PM
. . . and the Boring Company.
06/11/2019 3:41 PM
I said MOON ROOF.
06/10/2019 6:24 AM
I have had one colonoscopy, and I didn't have any issues either physically or psychologically with the procedure, so I don't understand why the audience or aftermath is a problem. Maybe it's just me, but as Lehman 57 said, there is only technicians in the room. True story as an aside, when I had my vasectomy done, they asked if some students could see the procedure. I said yes, only to realize that it was 7 or 8 young female students, talk about embarrassing!!
Cheers!
06/10/2019 8:51 AM
Embarrassing ? That could have presented itself with post operative testing procedures to determine if the surgery was successfull.
06/10/2019 6:24 PM
You still have the 21-day timeframe before "re-testing".
06/10/2019 11:04 AM
I to have had several colonoscopy's the prep is by far the worst part of the test, i have had several polyps removed and a tumor from my colon, i think cologuard or poop in a box,would be much easier.
Reply Off Topic (Score 3)
06/10/2019 10:08 PM
Yes, much easier, but for someone in a higher risk group (as you can attest), the better diagnostic tool would be a good thing. The Cologuard and other fecal sampling methods are not considered as good diagnostic tools as the colonoscopy.
I'd say you're LIVING proof of that.
06/10/2019 12:32 PM
If it doesn't eliminate the prep or the anaesthesia then the justification has to be the robot can do it better than an endoscope driven by a skilled technician.
Good Answers: 128
06/10/2019 7:32 PM
There are two portions to the endoscopy procedure--preparation to eliminate fecal matter from the colon and examination of the cleaned colon with a scope inserted through the rectum. It sounds like the small robot does not eliminate the first portion but significantly reduces the discomfort and need for anesthesia in the second portion.
--JMM
06/10/2019 10:29 PM
Eliminating anesthesia would be valuable for someone like me who has no one easily available to drive me to and from the test. With anesthesia they will not let me drive home, so I have to call a service to do that. It was free, but resulted in a very long trip to get home.
Lehman57
06/15/2019 9:31 AM
I did not have to have an anaesthetic. The procedure was 'uncomfortable' but very interesting.
06/15/2019 11:35 PM
Safer than a Gerbil! https://darwinawards.com/legends/legends1998-10.html
Marum.(Die schachspielen Katze)
Marum
70AARCuda (1); Brave Sir Robin (3); cblm46 (1); jhammond (1); jhowdy (1); jmueller (1); John Hadland (1); JRiversW (1); Lehman57 (2); mastrsmth (1); Ralph Hamilton (1); Rixter (1); SolarEagle (1); tonyhemet (2); XNuke (1)
