Previous in Blog: Aviation Seals and Aircraft Insulation   Next in Blog: Hydro Vac Truck Parts: Rubber Gaskets, Seals and Insulation
Aircraft Rubber Gasket Materials for Sealing and Insulation
Posted June 22, 2019 7:36 AM by Doug Sharpe
Aircraft rubber gasket materials provide environmental sealing, electrical insulation, flame resistance, EMI/RFI shielding, noise control, and other properties. They’re supplied as sheets, rolls, extrusions and moldable compounds. Water jet cutting, a tool-free gasket fabrication process, can quickly convert stock materials into specific shapes with close tolerances. Moldable aviation rubber is used for gasket bonding.
Even if your company isn’t part of the aviation industry, you can learn a lot about rubber by examining the following elastomers. Remember, however, that aircraft rubber gasket materials may need to meet specific industry standards or regulatory requirements that are particular to the aviation industry. The aviation seals and aircraft insulation that are fabricated from these materials also need meet strict quality requirements.
Learn More About Aircraft Rubber Gasket Materials
