Hydraulics Blog Blog
Hydraulics Blog
The Hydraulics Blog is the place for conversation and discussion about pumps and valves, flow control, cylinders, actuators and components, and mobile hydraulics as they relate to hydraulics. Here, you'll find everything from application ideas, to news and industry trends, to hot topics and cutting edge innovations.
Previous in Blog: Students Meet 'Chainless Challenge'
3 comments
Key Differences Between Hydraulics and Pneumatics
Posted October 20, 2019 12:01 AM by ahorner_22
Pathfinder Tags: fluid power Hydraulic pneumatic
Hydraulics and pneumatics are often grouped together. However, each offers its own distinctive features. When selecting which application to use, it is critical to understand the differences between each system.
The main difference between pneumatics and hydraulics is the medium used to produce power. Hydraulics use liquid for power generation. Pneumatics uses air to transmit power. These two systems, while very different, do share some common links.
Pneumatics is a type of system that is air-operated, which allows it to function at a low pressure. Pneumatics can be used in industries where hydraulics can’t, such as food manufacturing or pharmaceutical industries. These are “clean systems” that are free of contamination, unlike a hydraulics system which is preferred in engineering industries.
A pneumatics system’s initial cost is less expensive and easier to maintain. In general, the upkeep of a pneumatic system is less complicated to maintain than a hydraulics system. Since air is an abundant resource, a pneumatic system can collect air right from the atmosphere.
Hydraulic systems tend to be larger and more complicated than pneumatic systems. Hydraulic systems use a higher force since movement is slower due to larger load handling capabilities. The opposite holds true for pneumatics where a lower force is used.
Hydraulics systems also contain fewer moving parts, which assists with maintenance. Installation is more complicated, but after the initial investment, the cost is lowered. One of the main differentiating factors around hydraulics is its high precision capabilities.
Each of these systems has its advantages and specialties. Hydraulics are more powerful and meticulous then pneumatic systems, but that doesn’t mean hydraulics is always the optimal choice. Pneumatics aren’t as powerful, but they are cleaner and faster. It’s important to understand the processes and limitations of each system when determining which is best suited for an operation.
Good Answers: 119
Re: Key Differences Between Hydraulics and Pneumatics
10/20/2019 11:05 PM
Or, as I learned in tech school:
Pneumatic systems use compressible fluids. Hydraulic systems use non-compressible fluids. Pneumatic systems can use their medium to buffer changes in fluid movement. Hydraulic systems cannot without having additional hardware installed.
Re: Key Differences Between Hydraulics and Pneumatics. Fluid Phase Hybrids
10/21/2019 8:09 AM
Hybrid Systems and Non-Homogenous Phase Cross-Terms
Neither Hydraulics nor Pneumatics are, however, the most common
systems except where humans exert effort to cause them to be.
The nearly ubiquitous system is the hybrid system. That is,
systems which must deal with both liquid and gas phase fluids in
their conduits at the same time. Usually, these systems have a
dominant phase of medium. In other words, most systems are
pneumatic systems which must tolerate some liquid in them or
hydraulic systems which must tolerate some gas in them. Biological
systems are a good example. Respiratory systems are primarily
pneumatic but have sigificant operating characteristics due to a
small but not insignificant amount of liquid(mucus) in them.
Digestive systems are primarily hydraulic with a small but not
insignficant amount of gas(flatulence) in them. Home water supply
and waste water systems are similar. Supply systems are primarily
hydraulic with tolerance for air present in the system(bubbles).
Waste water systems are even stranger since they are hydraulic
systems with gravity rather than pump powered fluids and large,
significant volumes of gas(air) in them.
Often, significant operating mechanisms in these hybrid systems
come from the medium with the opposite phase as the primary working
fluid phase of the system. Lubrication is often the operating
mechanism which comes from material in the system which does not
match the phase of the primary operating fluid. Pneumatics often
use liquid phase lubrication(oil). Hydraulics often use gas phase
accumulators. Even in human designed systems, hybrid phase is
commonly used to achieve lubrication such as the oiler mister in
many shop air systems. Shop air is interesting since the traditional
filter, drier, oiler sequence of mechanisms is manipulating non-primary
phase elements in the conduit. "Filter" removes solid phase contaminants.
"Drier" removes water, a liquid phase contaminant. Then "oiler" injects
a required liquid phase lubricant into the predominantly gas phase
system.
Human created hydraulic systems can become faulty if significant amounts
of gas phase fluids are present the conduits. The fluid for which
hydraulic systems are named, water, is frequently rejected as the working
fluid for the system. Water is a wonderful hydraulic fluid with two
significant exceptions. The first is, that while water can behave as
a lubricant, it is also such a good solvent that it also tends to remove
lubricants designed to stick to the system's moving parts. Without proper
lubrication, friction generates heat, and the heat can evaporate the water.
The vapor phase of water is compressible, unlike its parent liquid fluid.
That compressibility disrupts the good hydraulic fluid characteristics
right where the system critically depends upon them. Therefore, most high
force, high power, hydraulic systems shun the very same eponymous fluid
that gives these systems their appellation. That is, hydra means water
but water usually cannot work well in extreme hydraulic systems with local
temperatures high enough to evaporate it.
_______________
thewildotter
10/22/2019 10:40 PM
Greek prefix etymology:
HYDRA = water, wet.
PNEUMA = air, breath.
70AARCuda (1); Hooker (1); thewildotter (1)
