Previous in Blog: Design for Manufacturing in Injection Molding   Next in Blog: Gasket Compression and Enclosure Sealing
5 comments
What’s the Difference Between Foam Rubber vs. Sponge Rubber?
Posted August 17, 2019 8:55 AM by Doug Sharpe
Did you know that there’s a difference between foam rubber and sponge rubber? Sure, the two terms are often used interchangeably. Unless you work in the rubber industry, the sponge next to your kitchen sink may seem similar to the foam mattress pad on your bed. After all, both are soft and compressible. Upon closer examination, however, saying that foams are identical to sponges is like saying that doing the dishes is the same as getting a good night’s sleep.
What’s different about foam rubber? And how does it compare to sponge rubber? The differences begin with ingredients and end with molecular structure. Foam rubber and sponge rubber also use different raw materials, chemical reactions, and production processes. Not all foam rubber is soft like your mattress pad either, and that enables applications for rigid foams in building and construction.
Learn More
Re: What’s the Difference Between Foam Rubber vs. Sponge Rubber?
08/17/2019 9:45 AM
Sponges grow in the sea...
...and foam comes from the mouth...
08/17/2019 10:24 PM
08/18/2019 8:32 PM
Both come from the sea; foam forms in the surf zone.
clint.bowman@comcast.net
08/18/2019 5:34 PM
Sponge came first.
Like the chicken.
Foam is used to support things..
Like the egg.
08/19/2019 6:09 AM
My simplistic view is the foam is closed-cell (individual bubbles) - whereas sponge is open-cell (the bubbles are interconnected).
clint420601 (1); horace40 (1); JE in Chicago (1); SolarEagle (1); StandardsGuy (1)
