Hemmings Motor News Blog Blog
Previous in Blog: The Black Ghost 1970 Hemi Challenger in Godfrey Quall's Own Words   Next in Blog: Open Diff: What Automotive Styling Feature Turns You Off?
5 comments
Watch This: Homemade Parts Cleaner Epicness?
Posted December 24, 2020 12:00 AM by dstrohl
As we mercifully close out 2020, we learned a few things about ourselves; not the least of which was that we didn't completely forget that we could still DIY the hell out of some things. If you're reading this, you probably came to your own version of that realization, too.
And one of the things we dig is this homemade ultrasonic parts washer! If you're anything like us, you've collected metric tonnage of vintage speed parts, go-fast goodies, junkyard scores you might just need someday, and piles of stuff that you haven't touched in a month of Fast 'N Furious releases, but that you know you'll want as soon as you get rid of.
You've probably got the DA sander in one corner of the garage and a jug of parts cleaner in the other. And somewhere in between, there's probably some sort of appropriate container and a roll of velcro. And we know you've got a little spool of wire or butcher's string or dead extension cord laying around, too.
Have any of you tried this homebrew hack? Got another tried-n-true trick for washing parts? Or, let us know if this works, once you've tried it. Tell you one thing: we see a decent garage sale in our future if we can get some of this stuff cleaned up around here...
Re: Watch This:: Homemade Parts Cleaner Epicness?
12/25/2020 9:23 PM
I ran a compressed air powered vibrator (little eccentric spinner) attached inside a laundry tub to provide vibration and foam in a process to wash oil from closely spaced plates. Keep a lid on the sink and it works pretty well!
01/01/2021 11:00 AM
Where are the pictures to "watch" ?
Re: Watch This: Homemade Parts Cleaner Epicness?
12/26/2020 11:28 PM
Very interesting! A couple of comments:
First, it's not ultrasonic, unless some components have harmonics in the ultrasonic range, or the relationships between the two kinds of motion in the sander result in ultrasonic movements.
Second, I was not familiar with the term "DA sander", and had to look it up. I gather that DA is synonymous with Random Orbital...
In any case, that's all semantics; if it works as shown, then I don't want to knock it!
12/27/2020 9:39 AM
I have a 40+ yr old Craftsman, all aluminum housed, "DA" sander. It stands for Dual Action. There's a lever on the side of the base that will switch it from straight linear stokes to orbital strokes.
12/27/2020 12:07 PM
Thanks. My all aluminum Craftsman tool is either just over 50 years old, or just under 60; I can't remember which of two possible times I could have purchased it. It is sort-of Dual Action; the motor has two heads: a drill and an orbital sander; no linear motion on the sander. My wife just used that sander to refinish her park bench a couple of months ago.
When I did a search for "DA sander", most of what appeared were random orbital sanders, plus one that appeared to be a disc sander, but was labelled DA. I presume that last one also had some form of vibratory motion.
dkwarner (2); Flash_In_The_Pan (1); Mfmatusky (1); Shoptruck (1)
