Hemmings Motor News Blog Blog
Previous in Blog: The Depression Nearly Killed Cadillac. Nick Dreystadt Saved It with Uncommon Compassion   Next in Blog: The World Needs More Vans, Even of the Photochopped Variety
3 comments
Not Just Black Boxes: Five Things to Know About Electronic Fuel Injection
Posted May 17, 2021 7:17 AM by dstrohl
Pathfinder Tags: electronic fuel injection
For something with as simple a purpose as delivering the right amount of fuel to an internal combustion engine, electronic fuel injection (EFI) remains a cultural flash point for quite a few people in the collector car hobby. To many, the transition from carburetor to EFI marks the transition from classic, DIYable cars to modern vehicles on which regular Joes can't turn a wrench. To others, though, EFI simply represents the best method for extracting greater efficiency from an engine.
Whatever one's preference, EFI became a mainstay of automotive engineering 40 years ago, long enough for an entire generation or two of EFI-equipped cars to pass into collectordom. And as it turns out, many of the people who work on those cars of the Eighties and Nineties and beyond - not to mention restomodders who have taken to adapting EFI to older cars and engines - have found EFI capable of producing powerful engines that retain street manners and even return decent mileage.
Not all EFI systems are created the same, however, and the past few years have seen multiple advances in fuel delivery systems. Here's what you need to tell the various options apart and to make the most of your particular EFI system.
Good Answers: 54
Re: Not Just Black Boxes: Five Things to Know About Electronic Fuel Injection
05/18/2021 3:27 AM
Back in 1969, Alfa Romeo started putting a diesel mechanical fuel injection system in their US spec cars. The system is called SPICA and has four small pistons which pump fuel into each cylinder (in front of the intake valve). The control end of the SPICA system is an analog computer that takes inputs from a number of sensors along with throttle position, then determines the amount of fuel that should be pumped into each cylinder. The SPICA pump is driven by a cogged belt that runs off the crankshaft. The SPICA system had four individual throttle plates (one per cylinder), until 1980 when they went to a single throttle body system.
Alfa Romeo used SPICA mechanical fuel injection until 1982, when it went to a Bosch L Jetronic EFI system with a computer for the fuel injection system and one for the ignition (spark). It cleaned up the emissions of the mechanical system, but the car lost a lot of the mechanical feel.
In 1990, Alfa Romeo went to the Bosch Motronic EFI system. The Motronic cars feel more like a Toyota. They're easy to start, need less maintenance, idle smoother and have more power and less emissions. However, they feel less special and the motor feels much more Toyotaish. The feel of the early Alfa Romeos was greatly diminished.
05/18/2021 11:05 AM
Interesting for owner of a Skoda diesel that worked fine until a recall to reverse the emissions fiddle. Since then half the injectors rapidly burned out, and cannot be refurbed.
duikerbok
Good Answers: 54
06/02/2021 3:30 AM
Could be the amount of fuel is too high for the original injectors, so they burn out. The electronic control (I believe it's a coil) may be held open too long and thus overheat.
I once drove a VW Toureg diesel (notorious for the VW diesel cheat) from Lompoc to Castaic (around 130 miles) on an 1/8 tank of diesel. A Toureg is a heavy SUV (nearly 2 1/2 tons). The EPA figures are 28 mpg. The fuel tank is 26.4 gallons, so that puts the fuel economy at close to 40 mpg. The fuel injectors were working about 40% less at highway speed, so they would last a lot longer and stay a lot cooler.
