From Instructables: explore:
The area that I live in has been in a drought for a year or more. As such we now have water restrictions on washing the car, watering the garden etc. Initially I set up a drainage hose from the washing machine outlet to containers outside to enable me to collect the waste water so I could water the garden. This process worked fine except for the back breaking work of emptying the waste water (grey water) onto various places in the garden. The next stage was to develop an automatic system that would distribute the grey water into the garden and have the following features. 1) Filter the water before sending it to the garden. 2) Automatic pump to allow water to be delivered to the high end of the garden. 3) Timer to prevent water stagnating in the tank. The system uses a wheeled trash bin which is made out of 5mm thick plastic (nice and sturdy). Grey water comes into the top of the bin into a filter. When the bin fills to around 3/4 full, a water level switch triggers the pump controller to turn on the pump sitting at the bottom of the bin. The pump continues to operate until the lower water level switch is triggered.
