Previous in Blog: World's tallest Ferris Wheel coming up in China   Next in Blog: Google at the gas pump
12 comments
The Truth About Tooth Decay
Posted November 07, 2007 8:54 AM
From LiveScience.com:
Are you worried that your mass consumption of Halloween candy this year will rot your teeth so badly that you will have the smile of a hockey player by next year?
Well, don't take this as an invitation to eat a dozen Zagnut bars in one sitting, but there are worse foods than candy to cause tooth decay.
Re: The Truth About Tooth Decay
11/08/2007 6:24 AM
I have always thought that acids were to blame for tooth decay, so seven years ago I decided to stop brushing my teeth and to cut out anything acidic. This experiment of mine showed me that that was the case! What I did was to use a tooth pick and dental floss plus mouth swilling with distilled water, I kept this up for six months,the results, my teeth were never effected in any way!!! In fact my teeth have become harder and glow a pale ivory colour. Brushing too much with toothpaste has been known for a long time to lead to teeth enamel loss. Spencer.
11/08/2007 8:43 AM
So why did you stop?
11/08/2007 9:17 AM
Hi Guest.
I only stopped doing this for six months to see what would happen to my teeth when I went back to traditional brushing. Since then I have carried on with my first experiment and found it to be best. Spencer.
United States - Member - New Member Technical Fields - Education - New Member Popular Science - Cosmology - New Member
11/08/2007 10:33 AM
Makes perfect sense from a chemist's point of view. Therefore, *gentle* brushing with baking soda should go a long way towards eliminating acidity (I really like Arm & Hammer's line of baking soda toothpastes).
Hence dentists' recommendation to use a *soft* brush instead of the "medium" or "hard" types. The soft bristles not only apply less direct abrasion, but they also decrease the pressure applied via the mineral particles in the toothpaste. The medium and hard brushes probably also damage the gums (soft brushes provide enough of the recommended stimulation).
Problems worthy of attack prove their worth by hitting back. -- Piet Hein
11/08/2007 2:08 PM
Why doesn't someone come up with an alkaline based gum or candy--to counter-act the acidity?
goosemydog
11/08/2007 3:45 PM
Unfortunately, alkaline (pH<7) substances taste bitter. Baking soda provides a much more agreeable alternative. Although only very slightly alkaline, it has the capacity to neutralize relatively large quantities of acid, and in the process produces a pleasant effervescence (fizz).
HCO3- + H+ ---> H2CO3 ---> H2O + CO2
The only problem with baking soda is that it tastes salty.
11/10/2007 12:06 PM
alkaline (pH<7)
The above is incorrect -- I should have written: alkaline (pH>7)
Good Answers: 7
11/14/2007 2:05 PM
A related discovery of my own:
For decades I had hypersensitive teeth and severe erosion of the enamel. A few years ago my doctor prescribed an acid blocker to treat my acid reflux condition. VIOLA! My sensitivity dissappeared! Unfortunately, the damage due to erosion is already done. I wish I had know about acid blockers long ago.
Bill Morrow
Bill Morrow
11/14/2007 6:25 PM
Thank you for mentioning this -- your comment just triggered an insight about my mother's sensitive teeth. She has acid reflux, but I had not thought of the connection that you pointed out. She started taking an acid blocker (Prevacid), after which she seemed to complain less about her teeth. But now I'll ask her about it in case she needs additional relief by upping the dose. She just switched to Nexium (much less expensive), so I also need to find out if this has the same protective effect.
Good Answers: 7
11/15/2007 9:27 AM
Gary-
I have been on Prilosec and Nexium. (Not at the same time.) Both medications provided relief for tooth sensitivity.
Bill Morrow
Bill Morrow
11/09/2007 1:55 AM
I thought the acid was caused by a specific bacteria. In fact, a number of years ago I read an article on a "vacine" that had been developed in Britain to stop the bacteria responsible for the acid production. I never heard anything since.
Looking at http://www.animated-teeth.com/tooth_decay/t2_tooth_decay_caries.htm
I found this:
"The acids that cause tooth demineralization (cavity formation) are produced by specific types of bacteria (mutans streptococci and lactobacilli) that live in dental plaque."
Anyway I figured a trip to Britain for some vacinations was in my future but I never heard anything about the vacine again.
Imagine what great thing it would be.
Oh well.
Gavilan
11/09/2007 5:46 AM
Hi Gavilan.
Yes you are right.
What I forgot to mention was that every evening I wash my mouth out with a mouth disinfectant to keep these bacteria at bay.
At 62 years of age I still have all my teeth, so I must be doing something right!
Spencer.
Anonymous Poster (1); bmorrow492 (2); Gavilan (1); goosemydog (1); Scapolie (3); svengali (4)
You might be interested in: Worms and Worm Gears, Leak Testing Equipment
