Aerospace Blog Blog
Aerospace Blog
Previous in Blog: MASU on Meteors: Comet 17P (Holmes)   Next in Blog: Masu on Mozzies: Undercarriage Part 2
11 comments
Test Your Knowledge About the Moon
Posted November 28, 2007 2:42 PM by M&M_aero
Pathfinder Tags: Moon
On cloudless nights, you can stare up at something gleaming down on you, lighting your path. Our calendars show its picture, telling us what phase it will be on each day. There are many old wives' tales and stories about the Moon. But when you look up in the sky, how much do you really know about Earth's constant companion? Test your knowledge with this top 10 countdown on cool facts about the Moon.
Number 10: Has the Moon always been there? Have you ever wondered how it was formed? According to a leading theory, the Moon was formed when a rock the size of Mars collided with Earth 4.5 billion years ago, when the solar system was just being formed.
Number 9: Have you ever looked up and thought, "Wow! I can see the whole Moon"? Well, you can't. The Moon and Earth are locked in orbit. Therefore, you only see one side of the Moon. Wondering how this is possible? A long time ago, the gravitational effects of Earth slowed the Moon's rotation about its axis. This effect stabilized once the Moon's rotation slowed enough to match its orbital period, the time it takes for the Moon to go around the earth. The part of the Moon we can't see from Earth is sometimes referred to as the "dark side of the Moon."
Number 8: Moon trees do exist. Well, kind of. In 1971, astronaut Stuart Roosa took some tree seeds with him aboard Apollo 14. While Alan Shepard and Edgar Mitchell walked on the lunar surface, Roosa guarded his seeds. After Roosa returned to Earth, his future trees were planted across the United States. To date, approximately 400 of these so-called "Moon trees" are still thriving.
Number 7: Have you ever wondered how the Moon got its very cratered and textured surface? It's the result of tons of space rocks hitting the lunar surface between 4.1 and 3.8 billion years ago. These "battle scars", as they are known, have not eroded much over billions of years for two main reasons. First, because the Moon is not geologically active in any significant way, moonquakes and volcanoes do not transform the landscape. Second, because there is little to the lunar atmosphere, there is no wind or rain to cause surface erosion.
Number 6: Do you think that the Moon is Earth's only natural satellite? If so, you may be wrong. In 1999, astronomers discovered a 3-mile wide asteroid that may be caught in Earth's gravitational grip. This, of course, would make the asteroid another natural satellite of our planet. Cruinthe, as this asteroid is called, will take 770 years to complete its horseshoe-shaped orbit around Earth. But don't worry about Cruinthe's departure before that. Scientists believe that Earth's gravity has caught Cruithne for at least 5000 years.
Number 5: When viewed with the naked eye, the Moon looks spherical and round. But in actuality, the Moon is shaped like an egg with one of the small ends pointed right at you! Therefore, the Moon's center of mass is not at the geometric center, but is instead about 1.2 miles off-center.
Number 4: The Moon quakes! When Apollo astronauts visited the Moon, they used seismometers and discovered that small Moon quakes originate several miles below the lunar surface. These quakes, which are thought to be caused by the gravitational pull of the Earth, are sometimes large enough to cause tiny fractures to appear at the lunar surface, allowing gas to escape from the Moon's core.
Number 3: The Moon could be considered a planet. The Moon is larger then Pluto and is 1/4 the diameter of Earth. Many scientists refer to the Earth-Moon system as a double planet.
Number 2: We all know that the tides go in and out, and many are aware that this is caused by the Moon. But have you ever wondered what actually causes this phenomenon that helps fishermen around the globe? The Moon's gravity pulls on Earth's oceans. High tide aligns with the Moon as Earth spins below. Another high tide occurs on the exact opposite side of the globe because gravity pulls the Earth toward the Moon more than it pulls water. The tug of the Moon does more than create Earth's tides, however. The Moon is actually stealing some of Earth's rotational energy, causing our planet to slow down by 1.5 milliseconds every century.
Number 1: Our Moon is leaving us! The Moon is propelling itself away from our planet with the rotational energy that it is stealing from Earth. Each year, the Moon moves approximately 3.8 centimeters higher in orbit. When the Moon was formed, it was only 14,000 miles from Earth. Today, it is more then 280,000 miles above us.
Our Moon is a fascinating celestial body. It has some intriguing characteristics and does some helpful things. So, the next time you look up at it, see the Moon for all that it is. And, of course, don't forget about the proverbial "Man in the Moon" smiling down upon us!
CR4 Aerospace Blog
Good Answers: 7
Re: Test Your Knowledge About the Moon
11/28/2007 6:06 PM
Ok from the top of my mind and not first looked it up on google or something.
We can actually see closer to 60% of the moon as opposed to the half stated. This is due to the wobble of the moon as it spins around us, it is perpetually going over the mark and exposing a bit on either side before "bouncing" back.
We are not at equal distance to our moon all the time, this results in a "larger" moon and a "smaller" moon at different times. The difference is as much as 11% and is visible with the naked eye.
Sometimes with a nearly dark moon, you can make out the whole of the moon as a light blue disc. This is called earth shine and is caused by light reflecting back to the moon from earth. This light makes for very good moon observing nights as the moon itself is dark and the blue disc will increase the contrast of the surface features like mountains. The best place to look on the moon for features is the dawn or dusk line. This is where the shadows will show you the crevices and craters on the surface.
When we have a lunar eclipse, it often turns the moon red, this is due to the light passing through the thin layer of our atmosphere, before it hits the moon. It has something to do with the wavelength of light that gets filtered out by our atmosphere.
Last one I can pull out of my head for now, Our moon is an oddball as it appears as virtually the same size disc as our sun at the distance it is in relation to us. This means we can enjoy both lunar and solar eclipses and makes the solar eclipses especially spectacular due to the visible corona that remains around the black out disc of the moon. There is as far as I know, no other known planet / moon / sun configuration where the inhabitants of the planet could see anything like what we can see.
That I think makes us special
Good Answers: 69
11/29/2007 12:45 AM
Hi M&M_aero. A nicely written and informative post; just 'cool fact no. 2' is slightly in error.
It is a very common misconception that the coastal tide highs align with and opposite to the direction of the Moon/Sun tidal force vector. The tidal vector stretches Earth in that direction, but it cannot lift the water above the surface by more than a millimeter or so. The water simply lifts with the surface and hence no tides.
The coastal tide mechanism is that water is being pulled horizontally towards those points, but because of Earth's rotation, it never heaps there. The water rather goes into an oscillating or rotating tidal current with a period of ~12h50m. When those currents hit a coast, high tide results. Add in the natural resonance frequencies of basins in the ocean an you have a very complex system of tidal cycles.
For more info, see a short CR4 Blog article on the tides that I've posted some year ago.
Jorrie
11/29/2007 5:52 AM
The moon is leaving us!
Hobbies - Musician - Tube Amps Only Please!
06/27/2009 12:55 AM
This is true I have read each year the Moon is a few inches farther from the Earth and "IS" moving away from us. Remember the laser reflector they put on the Moon on one of the Apollo missions? Well they bounce of that knowing the speed of light and measure the time travel of the laser beam to calculate the Moon's orbit distance! It is moving away from us I think I saw this on that great Astronomy show called "Nova"?
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
11/29/2007 10:25 AM
Here's a fun and informative site on Earth's moon:
\http://home.hiwaay.net/~krcool/Astro/moon/
11/29/2007 11:29 AM
So #5 is an explanation for #9. Ironic to think we have the benefit of viewing both the 'Light' and 'Heavy' side of the moon. While we don't see the "dark" yet much 'lighter" side.
11/29/2007 11:58 AM
No. 10 and no.1 don't quite fit together. If the Moon was formed by an enormous collision, as the most prominent theory suggests, then surely at some point the two protoplanets were in contact? Well, I suppose it depends upon what percentage of the collision matter had coalesced to form what we would describe as a moon, I suppose.
Nice blog, nevertheless. I'm off now to buy a moon-map.
Innuendo is not Italian for a suppository.
Good Answers: 7
12/01/2007 4:41 AM
As your location is a secret, I don't know if you can get hold of the Phillips range of astronomical maps. They are superb with a wealth of extra info just for keen knowledge absorbers like us
Leave you roost and fly out and find one! (unless you are a flying fox or a fruitbat, you might need help carrying it, they are not pocket size)
Good Answers: 88
11/29/2007 3:44 PM
Number 11: If you could see gamma rays - photons with a million or more times the energy of visible light - the Moon would appear brighter than the Sun! Consider this image of the Moon from the Energetic Gamma Ray Experiment Telescope (EGRET) in orbit on NASA's Compton Gamma Ray Observatory from April 1991 to June 2000:
Then the most sensitive instrument of its kind, even EGRET could not see the quiet Sun which is extremely faint at gamma-ray energies. So why is the Moon bright? Cosmic rays - ultra-high-energy charged particles - constantly bombard the unprotected lunar surface generating gamma-ray photons. EGRET's gamma-ray vision was not sharp enough to resolve a lunar disk or any surface features, but its sensitivity reveals the induced gamma-ray moon. The image was generated from eight exposures made during 1991-1994 and covers a roughly 40 degree wide field of view with gamma-ray intensity represented in false color.
11/29/2007 5:33 PM
Quite Impressive, but arent Gamma Rays harmful? Or is the dosage level too low?
Good Answers: 230
11/30/2007 10:37 PM
Gamma rays have poor penetration of almost all materials, including air.
Check it here:
http://science.hq.nasa.gov/kids/imagers/ems/gamma.html
Hope that sets your mind at ease.....
agua_doc (1); Anonymous Poster (1); case491 (2); Horrible Old Bat (1); Jorrie (1); maveric_manic (1); Mevel123 (1); Sparkstation (1); user-deleted-1105 (1); user-deleted-13 (1)
