Previous in Blog: Earth from Mars -- photo   Next in Blog: Space Station Could Beam Secret Quantum Codes by 2014
4 comments
U.S. supercomputer sets speed record
Posted June 09, 2008 9:50 AM
From Technology & Media - International Herald Tribune:
A U.S. military supercomputer has reached a computing milestone by breaking the so-called petaflop barrier and keeping the country on top in supercomputing. The machine is more than twice as fast as the previous fastest supercomputer, the IBM BlueGene/L, which is based at the Lawrence Livermore National Laboratory, in California. The new $133 million supercomputer, called Roadrunner in a reference to the state bird of New Mexico, was devised and built by engineers and scientists at IBM and Los Alamos National Laboratory, in New Mexico. It will be used principally to solve classified military problems to ensure that nuclear weapons will continue to work correctly as they age. Roadrunner will simulate the behavior of the weapons in the first fraction of a second during an explosion. It will also be used to explore scientific problems like climate change. The greater speed of Roadrunner will make it possible for scientists to test global climate models with higher accuracy.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: U.S. supercomputer sets speed record
06/09/2008 3:38 PM
Ya, but I heard Visa slowed it to a crawl.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
Good Answers: 88
06/09/2008 5:39 PM
I don't quite believe these numbers. LLL itself says that their expanded BG/L tops out at a mere 433 teraflops - well below the one petaflop cited in the article and substantially below records held by a number of IBM's newer P-series machines.
An IBM Blue Gene/P, for example, has four cores (4 ea PPC440+FPU compute engines) per node as opposed to two cores/node found in the L-Series machines. There are a number of benefits to packing more cores onto the same piece of silicon (an ASIC, in this case): For one thing, the fact that the cores share the same real estate means much shorter prop delays for communications between engines. Not only, but the quad-core parts are clocked at higher rates than their two-core, L-Series siblings. The P-Series' nodes also have larger L1/L2 caches plus more and faster DDR RAM. Topping it off is the fact that compilers can optimize a larger class of problems efficiently into parallel 4-processor groups. Not so easily done on an L-Series with its paltry two cores per node.
<gets down from pulpit>
I looked on LLL's website but found no reference whatever to their L-Series machine breaking the petaflop barrier, but would someone else here please also check out the facts? I, for one, don't believe the article's numbers.
Eu
Good Answers: 88
06/10/2008 1:03 AM
The article incorrectly states that the machine is a Blue-Gene/L, as suspected. But neither is it a BG/P. This machine is a new development from IBM, and you can read IBM's very own press release (and not some oblivious technoob-journalist's vague impressions) here.
I want one.
"Dear Santa..."
Popular Science - Evolution - New Member
06/10/2008 4:02 AM
You smell that? That smell! That SkyNet smell! Nuthin else in the world smells like that.
Smells like - Judgement Day.
DQ OR DQ NoT. XeR IZ NO TRi. - YODU
Bricktop (1); user-deleted-13 (2); Z man (1)
