In Part 1, I divulged in a freshman course taught at my
college that involved circuit building and the use of analog instruments.
One of the up-and-coming digital instruments is the
Rensselaer Mobile Studio board. I am involved in one of few classes to have
used this board and can vouch that it is a lab station in one. It is certainly
cheaper than having a whole lab set-up with separate instruments, but it is
less hands on and knowledge of the software is required to be successful.
This board has multiple additional benefits to a lab station
than having portability. It also has the ability to take differential
measurements across components. For an oscilloscope, you would have to have the
resistor ground or take multiple measurements to find the voltage across a
resistor. This board has the functionality of being able to take differential
measurements, which is a big advance from oscilloscopes.
Since this class was mainly a freshman college course, with
students whom may have never touched a resistor before, it was a solid stepping
stone for anyone that desired a general knowledge of electronics. As expected,
the foibles in the classroom required use of all five senses.
As a TA, thinking on your toes and having good circuit
debugging skills were crucial to being successful. Being able to see and detect
components in the wrong orientation makes solving student difficulties easier.
The smell of burning is an indication that a chip or component has been broken
and indicates needing a replacement. Hearing pops or other sharp loud noises
indicates a capacitor or LED has been damaged and to replace it. If a circuit
isn't working, simply feeling the chip with your finger can indicate the state
of the component. If too warm or hot, it can mean that you back-fed power into
the wrong pin of a chip and that the chip needs replacing. When using 9 volt
batteries, you can determine if it is good or not by licking it (I wouldn't
suggest this method if you don't know where the battery has been). The stronger
the tingle on your tongue is when you connect the two terminals, the higher the
voltage being transmitted.
These are just a few basic skills necessary in order to
successfully debug circuits, what other methods or skills are necessary for
adept debugging abilities?
Resources:
http://www.mobilestudioproject.com/
