Previous in Blog: US Supreme Court Allows Sonar Use   Next in Blog: Creepy Robot Threatens to Destroy Humanity
Intelligent iPill
Posted November 13, 2008 10:11 AM
From The Engineer:
Philips Research is set to unveil the iPill, an electronically-programmed capsule designed to deliver medicine at specific locations according to a pre-defined drug release profile. Camera pills have been around for a while now. In fact, the first was approved by the US Federal Drug Administration (FDA) back in 2001. But at next week's American Association of Pharmaceutical Scientists (AAPS) Annual Meeting and Exposition in Atlanta, scientists from Philips Research will be taking the wraps of a second generation device that sports even greater capabilities. Like its predecessors, the new so-called iPill (pictured below) is also a capsule that has been designed to be swallowed and to pass through the digestive track. Unlike previous devices, however, it can be electronically programmed to deliver medicine at specific locations according to a pre-defined drug release profile. The iPill determines its location in the intestinal tract by measuring the local acidity of its environment. Certain areas of the intestinal tract have distinct pH (a measure of acidity) profiles: the stomach is highly acidic and upon exiting the stomach the acidity of the gut sharply decreases and then becomes progressively less acidic from the upper intestine onwards. Armed with this pH information and data about capsule transit times, the location in the gut can then be determined with good accuracy. The iPill then releases medicine from its 11mm x 26mm drug reservoir via a microprocessor-controlled pump. According to Philips, the accuracy of the amount of drug dispensed against time measured was recorded to be better than 0.8 per cent in an average deviation of 0 to 95 per cent volume dispensed.
Re: Intelligent iPill
11/14/2008 9:10 AM
That is pretty wild!
What They Did
You might be interested in: Shoulder Screws, Self-sealing Fasteners, Captive Screws
