Previous in Blog: Mazda RX-8 controlled with iPod touch, Batman said to be jealous but coping   Next in Blog: Super-strong glass
2 comments
Flat Flexible Loudspeaker Redefines Public Addressing Systems
Posted April 02, 2009 9:43 AM
From Newlaunches.com:
Following instructions via public announcement systems at train stations or airports are like deciphering alien codes, making one wonder if they really on the right place all the time. Isn't it weird that if sound specialists can create perfectly audible sound in a packed cinema why can't it be replicated at a train station. A new speaker technology called FFL (Flat Flexible Loudspeaker) tech, enables speakers that are less than a quarter of a millimeter thick, light enough to be hung on walls or installed in ceiling tiles, and emit planar directional sound waves, which project further than sound from conventional speakers. The speakers could be concealed inside ceiling tiles in the home, printed with a design and hung on the wall like a picture or even wrapped around a lampshade. Car manufacturers are also interested in the speakers because they allow sound to be directed which means, the cars of the future may create sound from truly concealed sources.
Re: Flat Flexible Loudspeaker Redefines Public Addressing Systems
04/02/2009 11:54 PM
Finally, some engineering news. These "sound" cool!
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
04/06/2009 5:17 AM
Not so new! I saw and heard these at a trade show 2 years ago. They have some really interesting applications, but they do have to be shaped correctly to get the required directivity after which they are no longer flat. A small panel does not produce much volume, but a large flat panel produces a very directional beam which is useful if it is pointing the right way, and a problem if it is isn't.
For example, if these are wrapped around a pillar just above people's heads, they will have excellent horizontal dispersion, but will produce a strong horizontal beam firing straight over the audience. Bearing in mind the fact that sound rays tend to be bent upwards over a warm audience this would lead to most of the sound missing the listeners. Tilting the beam down-wards would require the panel to be tilted down-wards. Moving them lower would mean the front row get too much volume and block the sound to the people behind.
There are some locations that will benefit from these where speakers can be mounted at head height and the audience does not vary too much in distance from the speaker. They look attractive as components for phased arrays which do allow the beam of a flat panel to be slewed down-wards or sideways.
Like most novel speaker technologies they are another useful tool in the system designer's toolboxes but they are not a universal solution.
You might be interested in: Speakers, Sound Cards, Flexible Couplings
