Previous in Forum: Enhancing Natural Gas Burning in Tandoor   Next in Forum: Cherry Picker Arthritis
Fresh Water Hydrophore Tank Theory
03/22/2015 9:01 PM
Hello, experts....
I am a freshman in the ship building company. I have a question for F.W hydrophore tank theory. please see the below;
Lets take the case of hydrophore tank of 2.0 M3.
Condition under - pump on : 5.5 bar.g pump off : 6.5 bar.g , uterlized compressed air pressure : 8.0bar.g
1) How much will be compressed air volume for the above.
2) How to selct each cut in and cut off pressure.
3) How to calculate the flow rate of water at each cut-in pressure and cut-off pressure.
Please advise on to me..
Re: F.W hydrophore tank Theory
03/22/2015 9:36 PM
03/23/2015 4:09 AM
This is infomative for me. . Thanks
Re: Fresh Water Hydrophore Tank Theory
03/22/2015 11:06 PM
03/23/2015 3:55 AM
A1) There will be no flow, as the vessel pressure exceeds the selected pump cut off pressure. Therefore it doesn't matter what the vessel volume is.
A2) It is a matter of judgement based upon the flow and pressure needed downstream and the maximum number of starts per hour acceptable for the pump and its starting equipment. None of these figures is available in the original post.
A3) It depends upon the pump flow/pressure curve and the system characteristic curve, neither of which can be seen from here.
  • Design must start instead from stating the flow/pressure requirements downstream, selecting the pump(s) and then selecting the vessel volume.
03/23/2015 4:07 AM
Thanks for your advice.
03/24/2015 1:05 AM
what are the advantages over rubber bladder type tank for domestic and high rises
pnaban
Register to Reply 6 comments
lyn (1); pnaban (1); PWSlack (1); SeZaR (2); SolarEagle (1)
