Previous in Forum: Distance Between Two Objects   Next in Forum: Better Boiling With Nanotech
Earthing for Solar Power Plant
03/28/2015 5:40 AM
sir,
I had done the AC earthing & Dc earthing calculation,In solar power plant is there any specific calculation for Calculating the no.of earth pits for interconnected the structures/String monitoring control module.if so please share .
Thanks
Re: earthing for solar power palnt
03/28/2015 8:11 AM
Indian Standard 3053 springs to mind. Good luck.
Good moaning!
03/30/2015 3:56 AM
Sir,
Is it possible to explain it briefly
03/30/2015 12:51 PM
Not really. You need to invest in the standard, read it and then apply it.
Good moaning!
Re: Earthing for Solar Power Plant
03/30/2015 11:31 AM
The standards may vary from nation to nation, however, I do believe these are all based upon soil conductivity measurements. The correct answer: it depends!
Register to Reply 4 comments
Crabtree (2); James Stewart (1); kamatchi0515 (1)
