Previous in Forum: Grounding!   Next in Forum: Lighting Control
Important Exercise
03/29/2015 4:47 PM
Hi Brother and sisters.
I hope you are doing fine and great .
I wanted from u to solve a problem as follow:
A three-phase transmission line having a reactance of 120 ohms per phase is connected to a wye-connected load whose resistance is 160 ohms per phase. If the supply volatge is 70kV line-to-line, calculate
a) The line-to-neutral voltage per phase.
b) the line current per phase
c) the real and reactive power supplied to the load
d) the real and reacitve power absorbed by the line
e) The line-to-line voltage at the load
f) the voltage drop per phase in the line
g) The total apparent power supplied by the source
h) the total real and reactive power supplied by the source
Re: Important Exercise
03/29/2015 5:27 PM
Go fish.
Do your own homework. CR4 is not a homework cheat site; however, if you have questions about understanding concepts or how a portion of a problem is derived, these types of questions will be accepted.
03/29/2015 5:57 PM
Show your working. Show you're working.
Good moaning!
03/29/2015 6:14 PM
The reference material is supplied with the questions.....you have some reading to do...
http://bama.ua.edu/~shli/ECE454/Experiments/Exp7.pdf
http://www.amazon.com/Electromechanical-Energy-Devices-Power-Systems/dp/0471572179
03/29/2015 6:50 PM
Deleted. SE's already said it.
Reply Off Topic (Score 4)
Anonymous Poster (1); Crabtree (1); JohnDG (1); lyn (1); SolarEagle (1)
