Previous in Forum: Important Exercise   Next in Forum: Effect Of Under Ground HV Transmission Cables On Earthing
23 comments
Lighting Control
03/29/2015 7:51 PM
Hi,
Can i connect the following 2 lighting circuits together: one that is controlled from a photocell and the other one from a local switch?
Sama applies if I have 2 circuits: one controlled from occupancy sensor and the other one controlled from a switch?
Thanks
Re: Lighting Control
03/29/2015 8:22 PM
Yes. Of course you can.
They will no longer be independent of each other but you can do it.
Good Answers: 445
03/29/2015 8:34 PM
You can do it but it requires special switches known as "three-way" and three wires between between switches/fixtures. You will have to replace everything that you have and buy specially marked local, photocell, and occupancy switches. There are many variations of exactly how the wiring is done depending upon the exact feedpoint, switch, and light fixture location.
Here's a link to get you started, if you don't feel comfortable then hire an electrician to do the work for you.
03/29/2015 8:43 PM
I think that this is a case of "If you have to ask, you should hire an electrician".
Reply Good Answer (Score 4)
Good Answers: 445
03/29/2015 9:15 PM
Most definitely agree, and I've seen them screw it up too.
Good Answers: 225
03/29/2015 9:13 PM
Why would you want to do this?
You would need to ensure that both circuits are on the same breaker and phase, otherwise you could have problems with isolation or letting the smoke out.
Good Answers: 109
03/29/2015 10:12 PM
Put them in parallel and all is good.
03/29/2015 10:52 PM
Not if the combined amperage exceeds the circuit capacity.
Good Answers: 109
03/29/2015 11:05 PM
Thats for OP to decide.
03/30/2015 11:44 PM
Not really. It's for his local electrical code to decide.
Good Answers: 109
03/31/2015 2:52 AM
Since its a theoretical question we can live without the code. We dont even know where OP is or what the purpose is.
Maybe a school project.
04/02/2015 4:55 PM
If he is in the USA, he had better be following the NEC.
04/02/2015 10:35 PM
No, they reside in the Argonaut Society of eUnuchs (ASU). Their wiring standard is the Concerned Eunuchs Network, (CEN). They only care if it looks good.
04/03/2015 8:51 AM
Thanks. Well, he is on his own then.
Good Answers: 141
03/31/2015 1:10 AM
I hope they are operated from the same leg or phase. Otherwise fireworks guaranteed.
Plenty of room here
03/30/2015 9:15 AM
I hope both circuits are on the same breaker or at least the same phase.
Call an electrician. Don't forget to explicitly explain the logic of when you want each of these sets of lights are supposed to be ON and OFF.
Good Answers: 102
03/30/2015 11:56 PM
Didn't comprehend the question.
Whoever has answered thus far has assumed what you want to do and answered accordingly.
OP, instead of talking about circuits and connecting things maybe better if you talk about the desired function as a user....
I think you want two-way or stair switching....right? Maybe with a daylight/occupancy overide..or something else.
Guessing game.
03/31/2015 12:12 AM
The words, " photocell" and "occupancy sensor" , provide two different functions. A photocell sensor is usually used in an application where you want a circuit to be energized when there is change in ambient light, such as a security light turning on at dusk and shutting off during daylight hours. An occupancy sensor is more akin to a motion sensor where the circuit is energized regardless of the presence of ambient light or complete darkness.
Both the photocell and the occupancy sensor should already be wired with a " switch" in the circuit, being that a circuit breaker or at least a spst control.
03/31/2015 5:34 AM
What do you mean by connect together? Do you want them on and off at the same times, or, do you just want to use the same mains supply for both circuits?
What does "Sama" mean?
Good Answers: 27
03/31/2015 7:30 AM
yes it can be done! Logically the controls can be either an Or, And, or a combination of both circuits, as long as they all share the same phase..
vsar
03/31/2015 9:17 AM
The hard part is getting a definition of the pronoun "it".
Good Answers: 27
03/31/2015 10:51 AM
The "it" definition can be defined as anonymous as the OP...
vsar
03/31/2015 10:21 AM
Yes it can be done. Are you using line voltage or lower voltage AC/DC. If it is under 50 volts you can probably do it, otherwise get a professional. You will need a DPST switch and a DPDT relay of the suitable voltage. As per RedFreds concerns below.
Basically when the switch is off the relay is denergized and the motion detector is in control. When the switch is turned on, the relay is energized supplying current to the lamp.
The relay contacts are wired as follows, center or wiper goes to the device. The NC contact(s) go to a constant supply voltage. The NO contacts are wired to the relay energizing contacts. When the switch is activated, current is supplied to the relay coil as well as the N.O. contacts energizing the device.
I did this for the same reason. As our power is unreliable, I used a 12 volt LED system from Costco. Put a car battery on the roof with a 10 watt solar panel and charge controller. Works great.
Good Answers: 225
03/31/2015 6:29 PM
Simple answer is that provided the two circuits are on the same breaker and that load conditions are favourable, then connecting the two together downstream of both the sensor and the switch will produce a circuit where the lights are controlled by the sensor when the switch is open, and permanently on when the switch is closed. No ancillary equipment is required.
Reply to Forum Thread 23 comments
dvmdsc (1); IdeaSmith (3); JWthetech (1); lyn (2); Munster (2); RAMConsult (2); Randall (1); redfred (3); spades (2); tonyhemet (1); Tornado (2); vsar (2); Wal (1)
