Previous in Forum: LM2940CT-15 P+ Cross Reference Replacement   Next in Forum: The Size Of Sold State Relay
11 comments
S Band Radar
04/06/2015 6:47 PM
Ship S Band Radar scanner motor is tripping on overload, only 2 phase is taking 4 amps, and motor Full load amps is 1 amps. removed motor and checked all the phase ohms are 34 amps. again connected and the problem exists. Furno s band radar.
Re: S band Radar
04/06/2015 7:00 PM
Here's the problem: "all the phase ohms are 34 amps"
Good Answers: 225
Re: S band Radar
04/06/2015 7:01 PM
I guess that you meant to say 34 Ohms.
Did you check the bearings while you had the motor out? They would be my first suspect.
Re: S band Radar
04/06/2015 7:14 PM
Knowing not much more than you've said, all I can say is if the motor resistance is OK and the current isn't, then it has to be the supply to the motor that is not correct. Check your voltages.
Good Answers: 19
Re: S Band Radar
04/06/2015 8:26 PM
Onboard a ship you probably have a corrosion issue, check the bearings and the gearbox, could be an interference issue, did you run the motor while it was removed from the radar? check downstream from there.
Re: S Band Radar
04/06/2015 8:55 PM
There's no hope of ever getting this working again.
I'd scuttle the ship and swim to shore.
Good Answers: 137
Re: S Band Radar
04/08/2015 5:01 AM
LOL!
Re: S Band Radar
04/08/2015 10:54 AM
From the specs that Lyn so graciously provided you need 3 phase power to the motor. if you only have 2 you have your problem figured out.
Home is where the heart is!
Re: S Band Radar
04/07/2015 4:14 AM
Please discuss the problem directly with the equipment supplier.
Good Answers: 102
Re: S Band Radar
04/08/2015 2:27 AM
You have lost a motor supply phase.
Start measuring voltages towards energy source.
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
Re: S Band Radar
04/08/2015 4:58 AM
If it is right that only two phases are operating at the motor, that is likely to be the cause of the overcurrent. In effect, the two live phases are acting as a single phase supply across the motor which will be stalled, drawing excess current.
Re: S Band Radar
04/12/2015 7:10 PM
Checked the bearings they are good.
I have checked voltages 452,452,452, 60Hz between phases.
Yes we run the motor while it was removed from the radar it was taking 1 amps each phase
There is no problem with the energy source
Yes, you are rite Geoffrey36 only two phases are operating at the motor, which is likely to be the cause of the over current.
There is one circuit board between the supply and the motor to reduce the starting torque and to start the motor smoothly. Like a soft starter, that circuit board has failed and it was tripping on over load. The circuit board only controls one phase. Now we have connected directly and running it. Thanks for all your response.
Codemaster (1); Geoffrey36 (1); Jsquared (1); lyn (2); parthasarathy82 (1); PWSlack (1); Rixter (1); spades (1); Wal (1); Wrench twirler (1)
