Previous in Forum: job interview questions   Next in Forum: Sprinkler head
Storm Retention Pond
07/12/2007 10:50 AM
I have been asked to size a pump pit & pumps for a storm water retention pond. I have been dealing in pressure systems for so long that I've forgotten how to calculate gravity flow. How do I determine of the pumps be able to get inlet flow. The retention pond holds approximately 1.25 million gallons. They want to empty this is in a 24 hour period. The pond is approximately 10 feed deep at the the pump station. I will of coarse install a pump station deeper but I will have an opening in the station to get in. The pond is irregular shaped. I'm looking for a quick and dirty estimate to insure the water will get to my pumps. Are there any suggestions?
Re: Storm Retention Pond
07/13/2007 8:46 AM
My partner and I just did a simular thing. It's a little more complicated and expensive than one would think. The pump selection is critical. You will need to start the pump as soon as p[ossible to keep from buying a $1,000,000 pump. But if you don't take cavitation into account, you'll just burn up pumps. Contact me directly with more detail and I'll hook you up with the pump manufacture and the software (trial version) that will help you. I used a hydrology/hydraulics program called HydroCad. The free version will do what calulations for the basin but you will need to do some coversions. First only the pump uses GPM. The hydrology uses CFS. 1 CFS is about 450 GPM.
07/13/2007 11:20 AM
I just completed a couple projects that involved similar storm drainage pump stations and detention basins. I would suggest contacting a local Civil Engineer specialized in water resources. There are many issues to consider when design a detention pond and pump station that can easily be overlooked in the design process, unless you have been in the practice.
07/16/2007 11:53 PM
we had numerous storm water DETENTION ponds. gravity outflow to empty in about 24 hours.
one serious problem was that the ponds were built for and by each development. this ensures that there will be kids near and in the pond area. we required 4 ft high fencing, so toddlers cant get in, but adults can climb over to rescue any older kids in trouble. a nearby town had a teenager get sucked into to outlet and drown. we then required an outlet structure made of rebar like material, slanted surface so debris could be raked out while flooded. outer bars of grid structure should be upright rather than horizontal ones to facilitate rake. area of screen should be about 10 times outlet pipe diameter, so water pressure wont hold victim against screen.
Register to Reply 3 comments
Anonymous Poster (1); jrpeck (1); M Chasin (1)
