Previous in Forum: Red Hot Turbos on Cummins QSM   Next in Forum: Bonding Stainless Plates
Design Conditions for Pipe Stress Analysis
04/20/2015 9:13 AM
Hello,
I am having confusion with respect to temperatures which I need to select for a pipe stress analysis. Do I have to consider the Minimum Design Temperature (zero DegC) for stress analysis or is it enough to take only installation temperature (21degC).
My temperatures conditions are
T1: 84 DegC (max design temp)
T2: 0 DegC (minimum Design temp)
T3: 52 DegC (operating temp)
or the below conditions are ok?
T2: 21 DegC (Installation temp)
When I change temperature T2 from 0 to 21 Deg, expansion case stress ratio reduces drastically (from 92% to 7%).
My opinion is that minimum design temperature is for selecting the material so that it doesn't experience the brittle fracture. And upto 21 DegC there is no thermal expansion so we do not need to consider the 0 (zero) DegC for stress analysis.
Thank You
Re: Design Conditions for Pipe Stress Analysis
04/20/2015 9:18 AM
Line expansion is normal line addressed into the process line design, with expansion joints or loops.
04/20/2015 10:01 AM
  • There would be no point in taking minimum zero degrees centigrade if the pipe were never exposed to such temperatures, were it installed in Singapore ambient for example.
  • Likewise with 40 degrees centigrade were it to be installed in Tromso ambient.
It is the ambient conditions overlaid with the process conditions that determines the temperature range that the pipe will experience, and these temperatures are the ones to be considered in the design. In the example stated, the maximum is 84degC and the minimum 0degC.
Simples.
Good Answers: 61
04/20/2015 3:39 PM
Just my opinion:
- Design Temperature if a fictitious number and should only be used for pipe wall calculations.
- The Maximum/Minimum Operating Temperature is a real temperature and is the proper factor to use for Thermal expansion/contraction calculations for Piping systems.
If you use the Design Temperature then you are 'over designing' the system resulting in added cost.
Do it once and do it right
04/20/2015 3:47 PM
its a small, small world.
04/21/2015 2:32 AM
If I were designing a system, I consider the maximum and minimum temperatures tha t the system COULD be e=possibly exposed to.
Casper71 (1); PennPiper (1); phoenix911 (2); PWSlack (1)
