Previous in Forum: Reg:Transformer Polarity   Next in Forum: Big Capacity Motor Drawing Extra Current Than Small Rating
Mainboard of the MULLER
04/28/2015 1:45 PM
I have a tape loom mainboard of rough MULLERnow I have some problems:1. the machine is not operating khi stable, at runtime, while not2. i do not know its block diagram look like?I do not know if anyone Ever fix it yet?I hope will help me know người about itThank you very much!
Good Answers: 140
Re: mainboard of the MULLER
04/28/2015 3:17 PM
Best advice I can give you is... call the maker of this machine. With the language barrier in place, getting help from this forum in any meaningful timeline is just about impossible.
04/28/2015 3:24 PM
Use the telephone to contact the manufacturer.
Good Answers: 122
Re: Mainboard of the MULLER
04/28/2015 3:38 PM
I suggest you check all feedback circuits reporting to the board for loose, dirty, or broken connections as well as dirty or broken machine sensors.
Dirt & lint will raise havoc with the sensors and feedback signals.
I also suggest you examine the machine thoroughly for loose, broken, and missing bolts.
You also need to check all machine bearings for loose fit and excessive wear.
If you do not find any issues you will need to contact the Original Equipment Manufacturer Technical Support Group for guidance.
Good luck and stay safe
04/28/2015 7:06 PM
We need the make and model of loom and any info on the board...You should have a backup main board for swapping during troubleshooting and repair....it's much faster to just swap the board to see if that's the problem...if it is then you can repair it....
04/29/2015 3:22 AM
Can I simply ask, what is a Muller machine?
That appears to be quite old technology as well looking at the picture....
Here a "Muller" is a "Miller" as in making flour!!! (Though we do spell it slightly differently with a "ü"!!)
Just being nosy, sorry!
04/29/2015 8:07 AM
That's the brand I believe...
In action.
04/29/2015 2:01 PM
Ah!
Many thanks.
Register to Reply 7 comments
Andy Germany (2); North of 60 (1); PWSlack (1); SHOCKHISCAN (1); SolarEagle (2)
