Previous in Forum: Poor Idling For Toyota D4 3s-FSE Engine   Next in Forum: Rear View Mirror
10 comments
Calculating Water Flow For Axial Flow Pump
04/30/2015 8:26 AM
Can anybody help me with the approximation of the flow out of an axial flow pump. At the moment is the best method I have is like this:
Radius of propellor x radius of propellor x Pi = surface area of propellor.
x pitch of propellor = "volume" of air displaced in one rotation.
x RPM (rotations / minute) = volume of air per minute
/ 60 = volume of air per second.
But what if I have a pitch distribution throughout?
Re: Calculating Water Flow For Axial Flow Pump
04/30/2015 9:05 AM
Propeller efficiency might be around 0.7, depending on lots of stuff.
04/30/2015 9:16 AM
Thanks.
But i was looking for something like a better way to approximiate the flow out of the impeller?
04/30/2015 9:34 AM
Look at the pump curve for the pump.
Call the pump manufacturer and ask them.
Put a flow meter on it.
Hobbies - CNC - New Member
04/30/2015 10:01 AM
Typically a "Bucket and Stopwatch" test is great for any pump with ports smaller than 2" on the output.
  • Get a bucket of appropriate size. 5 Gal. - 10 Gal. - 50 Gal.?
  • Have a stopwatch or timer ready.
  • Turn on your pump and direct the flow outside of your bucket.
  • At the same time, actuate your timer and direct your flow into the bucket.
  • Time for one minute.
  • Direct the pump flow out of your bucket and turn off pump.
  • Measure the amount of water in your bucket.
  • You now have an approximate GPM.
This is only an approximation as it does not take into account the restrictions of the piping that may be installed in your set-up.
Good luck.
Bryan
Good Answers: 102
05/04/2015 5:08 AM
I have resorted to this method but in litres/second.
If you perform the test with the extant as built piping in the path of the test then it's right on the money.
05/04/2015 4:19 PM
You're correct. This method is very accurate when it is tested as built.
04/30/2015 12:26 PM
The pump manufacturer probably can. Do you know how to use a telephone?
Good moaning!
Good Answers: 266
04/30/2015 3:42 PM
You forgot that the hub diameter of the propellor has to be subtracted.
United Kingdom - Member - Not quite retired Member
Location: Up an araucaria araucana tree, South London, United Kingdom
05/01/2015 5:08 AM
Crucial to the flow through any rotodynamic pump is the net positive suction head (NPSH) and the discharge head. Simple pitch and speed calculations are valid only where the head difference is negligible (ships are pumps inside-out - the calculations by Icemaster are propellor velocity calculations).
Rotodynamic pumps have flow/head curves for each rotational speed.
05/01/2015 7:52 AM
Which one did you order? Or what does the nameplate say?
Register to Reply 10 comments
Crabtree (1); Geoffrey36 (1); Icemaster (1); lyn (1); Massey (1); Original_Macgyver (2); ozzb (1); Tornado (1); Wal (1)
