Previous in Forum: Mass flow measurement-hot air   Next in Forum: Ni Plating thickness
metal spring at high temperature
07/13/2007 3:02 AM
Looking for a metal spring ( or the metal to make the spring of), to operate at 250-280 deg C, and retain properties.
thanks
Pes
Re: metal spring at high temperature
07/13/2007 11:09 PM
The best steel for this kind spring are SAE 6150 or 9254/52 , Cr-V or Cr Si. I hope to help you. Don't hesitate to contact me, Best regard, ccvallino@hotmail.com.
07/14/2007 3:21 AM
Almost all Spring made from Spring STEEL ARE QUENCHED from ABOVE 900•C and tempered at above 500•C.
At 280•C the Springs will continue behaving like the original ReadySprings-with only just a little (6%) reduction of the Spring's yield strength.That strength will be restored when spring comes back to room temp.
If you want to operate the Spring only at high Temp.- same considerations of property/cost as at room temp.
07/14/2007 7:33 AM
Do a Google search on "high temperature springs". Various materials are used. I happen to like the inconel alloys, but final choice will depend on detailed requirements such as creep, yield strength, fatigue, cost, etc.
Good Answers: 94
07/16/2007 5:12 AM
I would agree with the suggestion to use Inconel, it keeps it's spring properties after repeated temperature cycling.
Register to Reply 4 comments
Anonymous Poster (2); MUKULMAHANT (1); Nigh (1)
You might be interested in: Spring and Wire Forming Machines, Spring Pins
