Previous in Forum: CNC Spindles!!!   Next in Forum: Query
8 comments
Ideal Cross Laser Alignment in Heat Transfer Machine
05/08/2015 10:22 PM
I want to share my selection of Berlinlasers cross laser alignment placed in a heat transfer machine.
My idea is to using red cross line to align the garment when is placed in the base of the machine to be printed. The operator only need to place the garment exactly where cross line label will be applied. Users can also try to use laser alignment tool as well. It is very practical and applicable in multiple fields.
industrial laser alignment solutions
Re: Ideal Cross Laser Alignment in Heat Transfer Machine
05/10/2015 1:43 PM
...share your selection. Please do! What did you select?
Using a laser cross for alignment is hardly a new idea. Perhaps for T-shirt printing it might be...
Welcome to CR4!
05/10/2015 4:26 PM
It's a very good non contact for placement such as yours idea, but it has been available and used for quite some time.
05/11/2015 8:23 PM
thank you very much for your kind reminding. I will try to know more about this application online.
05/10/2015 8:11 PM
My Berlinlasers 650nm 10mW red cross laser alignment using experience is as below:
Working distance: 40cm
line thickness: about 1mm
Laser wavelength: 650nm
cross degree: 10 degrees
output power: 10mW
The operator has just made quite nice place of garment while the label be applied. This technical data is just made for your reference.
05/10/2015 8:14 PM
The using experience of berlinlasers red cross laser alignment is as below:Working distance: 40cmline thickness: about 1mmsize: 8cm*8cmLaser wavelength: 650nmcross degree: 10 degreesoutput power: 10mWThe operator can make exact placing of garment with the assistance of cross line measuring tool. I hope this reference technical data might be helpful.
05/10/2015 10:34 PM
I prefer the structure of your post #3 over the single paragraph.
None of your posts have been off topic, so uncheck that box near the bottom before posting.
Do you have a model and/or source in the US for that laser indicator?
05/11/2015 8:25 PM
Thank you for your approval. I just get this laser alignment tool from its online shop. It might not take long time for delivery.
Good Answers: 94
05/11/2015 4:22 AM
You mean kike this one? One of many makes currently available in th emarketplace.
Register to Reply 8 comments
bosummer (4); dkwarner (2); Nigh (1); phoenix911 (1)
