Previous in Forum: chemical toileta   Next in Forum: Detection of Arsenic and Arsenic Compounds in Water
10 comments
Cleaning Concrete From Glass
07/13/2007 11:09 AM
Sir-Madam;
We are a company in Quebec that are in the cleaning business-When cleaning Glass Windows after the building is completed we encounter globs of concrete-mortar
on the window- we use water and a razor blade to remove the concrete and it leaves a streak -Have you a product that we can use to do the cleaniing??-Can we purchase it in Canada-Thanking you-I remain
Harry Budnick
Re: Cleaning Concrete From Glass
07/13/2007 12:37 PM
I'm not a chemist and haven't tried this so try at your own risk!!
I would have thought that as concrete is fairly alkaline in composition a weak solution of acid should remove any residual streaks of concrete left...
Sulphuric acid doesn't attack glass, so why not try a weak solution to remove it?
John.
Good Answers: 40
07/13/2007 12:37 PM
Here are some tips on proper cleaning techniques:
http://www.peepercompany.com/storm.cfm?funnelaction=268
Here is a product. You can find distributors on the site under "distributors:"
https://romixchem.com/romix_cart/products.php?cat=10
07/14/2007 2:37 AM
Techno --Excellent web sites --
Thank you, I learned some new stuff.
07/13/2007 8:39 PM
White vinegar will take it off ....
07/16/2007 9:38 AM
....because it contains acetic acid.
Acetic acid is far easier to handle than the commonly-used mineral acids like hydrochloric (or muriatic!) and sulphuric; in particular, the other two will try to rot other things it comes into contact with, like the frames holding the glass up perhaps! Acetic acid, white vinegar, is a good suggestion.
BTW: most proprietary window-cleaning sprays contain a measure of acetic acid in the mix, together with various surfactants. Which is why they work.
Safety - Hazmat - New Member
07/14/2007 1:56 AM
Dear sir,
try BREX from chemsearch.sankar
07/14/2007 2:29 AM
Not only will the concrete scratch (streak) the glass -- a razor blade will also mess up a pane of glass if too much pressure is applied or if the razor has broken edges or a bur on the edge. I do not have an effective method or product to suggest, your way is probably the way I would try too (very carefully).
I am surprised that the construction project manager allowed this sloppy work to happen and should hold the contractor responsible for the damage or cleaning of the concrete.
Good Answers: 32
07/14/2007 10:51 AM
You may want to try Muriatic acid (chemical name: hydrochloric acid). It is used to clean mortar and cement off of bricks, so it should work.
Tad
07/14/2007 2:25 PM
I've never heard hydrochloric acid called that before, muriatic acid eh?
I shall have to use that name it sounds so much better than hydrochloric, I know I've a few pints of the stuff in the chemicals box....
07/16/2007 10:15 AM
The Sweet Science
Sugar solution does the job without danger.
Everything old, is new again.
http://romixchem.com/romix_cart/back_set.php
The purpose of a system, is what it does.
Electroman (2); hioptemp (1); PWSlack (1); sbfwtx (1); Tad (1); techno (1); user-deleted-5 (2); vsankar (1)
