Previous in Forum: Scientists Make Nanofibers Using Fridge Magnet and Ferrofluid   Next in Forum: API 5L
13 comments
Anyone Knows How To Make This Tree Profile?
05/13/2015 8:17 AM
A steel frame tree like this
How to make the trunk? Concreting or cladding?
Thanks
Good Answers: 266
Re: Anyone knows how to make this tree profile?
05/13/2015 8:39 AM
Cladding over a fine wire mesh. Supported by the triangular structure in the first image.
On the second image you can just barely make out the mesh at the top where it has yet to be covered.
Hobbies - CNC - New Member
Re: Anyone Knows How To Make This Tree Profile?
05/13/2015 9:15 AM
When I was working in the movie industry, we made many trees for commercials. Being that it only had to last for about a few weeks, we used a rebar foundation that was welded together in the rough tree shape and then we used 1/4" steel for the rough shape and then chicken wire and window screen for the finished shape. When we finished with that part of the construction, we called in a company that applied a 2 part isocyanate foam that became the rough exterior. The artists came in and carved the finished shape and then it was either painted or covered in the isocyanate foam hard-coat and then painted. it all depended on what the art director wanted.
The same applies to concrete, however, the frame must be able to support the weight of the concrete and the concrete will be sprayed onto the form and carved immediately into the tree shape.
05/18/2015 2:04 AM
Do you know how to put the leaf into the metal branches?
Real leaf or artificicial in photo?
05/13/2015 9:32 AM
05/13/2015 10:01 AM
Solar Eagle,
Look deeper behind the scaffolding and you will see a tree being fabricated.
That is unless you were being facetious.
In that case you're right, it's powder coated scaffolding.!
05/13/2015 12:06 PM
I can't see the tree for the forest....
Ahhh Magoo, you've done it again!
05/13/2015 12:30 PM
I know, I had to put my glasses on too!
05/14/2015 9:26 AM
It's kind of hard to make out what's going on in those pics, way too many paralel pipes in the foreground and background.
I hate to say it(1) but I literally cannot see the forest for the trees.
Notes:
  1. I Really hate saying that, but it's the only phrase that comes to mind, I can feel it chasing other phrases away before i can see them. And the pun is so bad *I'M* in physical pain from it.
05/14/2015 12:18 PM
...and when you are in pain, it must be really hurting. I could not see the tree for the forest of scaffolding...at first.
05/14/2015 12:37 PM
The only way I saw it was his explanation of a tree and the first picture has a different TRUSS style vertical column and the third picture has the trunk base and root structure. I had to look at the pictures several times before I found the "tree inside the forest"
05/15/2015 8:30 AM
I will follow up the tree construction and share here later
05/13/2015 3:14 PM
How to Build a Concrete Tree in 7 Steps
Cool concrete tree house...
Now this was an ambitious project....
05/15/2015 10:59 PM
Get a steel frame tree ( ferrous constructicus ) seed and water well. Wait,,,,
Register to Reply 13 comments
adreasler (1); James Stewart (1); JIMRAT (1); Original_Macgyver (4); ozzb (1); SolarEagle (3); youngken (2)
