Previous in Forum: Urban Racer   Next in Forum: Takata Airbag Recall Doubled
57 comments
Tyre Repairs Again
05/20/2015 6:02 AM
My car has no spare tyre; instead I am provided with a can of foam and an inflator. I used this to fix a puncture for my daughter. The repair worked, but the instructions are not to drive for more than 100 miles and not to exceed 70 mph, so the repair is not intended to be permanent. Unfortunately the garage refused to make a permanent repair, saying that it was not possible after a foam repair. The tyre was quite new, so making a temporary repair seemed to have been an expensive mistake.
However, I can find no reason for not doing a definitive repair. I could perhaps accept that it might be difficult to find the original hole, but does anyone know of a better reason?
Good Answers: 137
Re: Tyre Repairs Again
05/20/2015 7:11 AM
Not offhand, but I suppose you could try other repairers.
Another reason to deplore the trend away from a proper spare. As a matter of interest, does your daughter's car have a spare? If so I'm sure next time you'll fit the spare and take the punctured one for repair!
05/20/2015 11:04 AM
Thank you all for your responses. Unfortunately my daughter's car is one without a spare. If it had happened near my house it would have been my jack and my toolbox (much used on former vehicles) and the wheel off and away for a plug to the tyre. Unfortunately we were too far away for that.
Good Answers: 26
05/20/2015 7:57 AM
BS! All they have to do is wipe out the inside of the tire. They are just trying to sell you another tire.
Good Answers: 69
05/20/2015 8:31 AM
But of course !, I was in the same situation (myself) a few months ago. But before using the fix-1-flat, I took a picture of the puncture, covering sorrounding threads and rubber branding, so I could locate the puncture at a later time (1 week) and then simply used a strip plug soaked in rubber cement.
Good Answers: 122
05/20/2015 8:58 AM
It depends on where the puncture was/is located and how bad it is.
If the puncture is in or too near the sidewall no competent repair shop will touch it.
If there is too much reinforcement cord damage or the puncture is in between the tread in one of the deep grooves, most tire repair shops will not attempt permanent repair.
The repair shop's liability & risk for attempting the repair obviously is greater than they are willing to accept.
05/20/2015 9:10 AM
For less than the cost of one repair, you can buy a tire repair kit to repair dozens of tires and you don't have the repair person telling you that it can't be done.
Good Answers: 137
05/20/2015 11:41 AM
Do you mean a cold vulcanising kit? I believe Rema Tip-Top was the original in the 60s but there are others nowadays.
I don't think it's practical for most motorists. Getting the tyre bead off the rim isn't easy without tyre shop kit. I used to do it by laying the wheel flat, rest a stout plank on the sidewall, drive the car up the plank and finish by kicking the bead down with heavy boots. Then tyre levers needed to get at least one bead over the wheel rim. Can then reach in, buff the area round the puncture and apply a patch, but many tyres have raised ribs on the inside spaced about 30mm, and sod's law says the hole will be next to one of them, making it more difficult.
I'm a keen DIY-er and I've done that in the past, but these days (older, less energy, more money) I'd rather pay a repair shop £10.
05/21/2015 8:50 AM
No. It is just a reamer, a needle, and some rope pieces with tar on them. It takes about 60 seconds to repair a simple puncture.
05/21/2015 9:21 AM
That's good for 'quick fixes' on older tires, but if you read the pamphlet that the tire dealer should have given you when you got the new tires, you will find that it is an 'operator's manual' for tires, explaining how and why to rotate tires, and how to properly fix flats.
That 'reamer and rope' kit is only HALF the flat repair system, the other half is a rubber patch you apply to the INSIDE of the tire with rubber cement. And there's a third 'half' to the equation as well: Visual inspection of the puncture from both sides to determine if the steel belting has been compromised.
Using the 'reamer and rope' kit without inspecting the interior of the tire will void the warranty on the tire. That's why I said it's okay on older tires. Once the tire has worn down to where you won't get a 'prorated' discount on the replacement, or you've had it long enough for the warranty time to run out, feel free to use the reamer & rope all you want.
As for the mechanic who won't work on a 'fix-a-flat' inflated tire, either the puncture is in a spot that 'kills' the tire (in other words, cannot be safely repaired, like a side wall or deep tread puncture), or the mechanic simply was not trained on how to work on 'fix-a-flat' inflated tires, or the garage has a blanket policy about f-a-f tires to protect themselves from liability issues.
05/20/2015 9:24 AM
"... saying that it was not possible after a foam repair."
Agree with texasron, that's baloney. I had the same tire issue you describe, used the same solution, and when I took it to a tire shop and told him what I had done, he said "No problem, I'll just clean it out."
SHOCKHISCAN makes a valid point about where the puncture is having something to do with repairability. However, a sidewall puncture would likely not get plugged with the foam stuff.
Hobbies - CNC - New Member
05/20/2015 10:09 AM
When I have had an issue with the tire shop saying they don't want to or can't repair a tire after the application of FIX-A-FLAT, it's usually because they don't want to get the sealant all over themselves so they give you a line of B.S. and sell you a new tire. Go elsewhere and have them explain why if they say the tire must be replaced!
05/20/2015 10:38 AM
I had one garage owner tell me it was because the stuff was so flammable or explosive even, that is why he refuses to work on tires with Fix-a-Flat in them.
05/20/2015 11:06 AM
I just perused the MSDS and it says the material in the Fix-a-flat can is combustible but not readily ignitable and gives it a rating of 1 meaning it will burn if in contact with an open flame but will not explode.
That was for the brand Fix-a-flat and not one of the other brands!
Good Answers: 94
05/20/2015 11:59 AM
Possibly the combustible part is the propellant in the can, not the cured mixture.
05/26/2015 8:14 AM
Yes. The propellant is probably propane.
05/20/2015 12:06 PM
I would replace the pair of tires, front or back, that the failure occurred, and keep the good one and put it on a spare wheel....
Good Answers: 97
05/20/2015 5:04 PM
When I got fed up with punctured tires, I shopped for new ones by how much they weighed. The tire dealers thought I was cracked, but I have not had a puncture since. Some brands are like baloney skins.
CRTL-Z
05/21/2015 6:03 AM
LOL!!
Not a bad idea, thanks for sharing!!!
05/20/2015 11:24 PM
I was sold a can of "Slime" (Yes, that is what is is called)…The tire mechanic told me that all of his off-road riders used it (both motorcycles and dune buggies), and that it worked great. My concern with the older Fix-A- Flat was the tire balance at speed…Leave it sit for a while, and the load would sag into the lower part of the tire, and create a monster of a vibration.. As an aside, I always carried one in my old VW bus, for off-road Baja adventures, and needed it after waking up in an old fish camp site, with broken glass spewn about. This was many moons ago, before kids, and With my wife with me on her first foray into the great unknown, 600 Km down on the Pacific Side, I needed to make all right. Removed the tire, filled as instructed, and rolled the tire up and down sand dunes until it sealed..We found a Mexican tire shop 30 Km later, and he had never seen the stuff that greeted him when pulling the tire. It went on forever. A $20 bill went a long way to alleviate the mess, and we were on the road again, and made it home safely, 3 days later. By the way, to seat the rim, he used a thimble of gasoline in the tire, adjusted the tire on the rim, lit it, and the tire slammed into position…Amazing to see…No problems here!
05/21/2015 6:08 AM
You forgot to mention that he ignited it!!
For anyone who has not tried this:-
Normal Tyre
Off Road Tyre
05/21/2015 1:42 PM
"lit it" is American for "ignited it.
What I don't understand is how he managed to light (ignite) the gas inside the tire. I'm assuming he used the pressure created by the burning fuel to set the tire edges into the rim...
05/21/2015 2:43 PM
Try looking at the YouTube links I posted!!
Good Answers: 97
05/21/2015 5:20 PM
I had a girlfriend that could do that without gasoline. Her name was Amelia Airstart.
CRTL-Z
05/21/2015 6:06 PM
I sent a reply earlier, but it didn't get posted.
Thanks! Now I have seen the light!
05/21/2015 5:20 PM
Maybe, Mr. Mac can get a you tube video of " The way a Mexican tire mechanic fixes tires ".
05/21/2015 6:04 PM
05/22/2015 10:47 AM
Do you want to know how to stop that happening?
05/22/2015 11:01 AM
Of course! I presume the answer is to type the whole message before selecting and submitting the link...
05/22/2015 11:16 AM
You are on the right road, you just need to add a few <CR/LF>s (Enters) after the link, but before you activate it......
But basically its simply poor programming in the CR4 editor. The problem was there since the first day I joined CR4.
For me, I always add a few extra <CR/LF>s also when adding pictures, before enlarging the picture, otherwise you cannot add text after enlarging the picture, after the picture (if that makes sense!!).
Whoever designed the editor, did not have much of a clue.....fixes take months if not years.....or even forever!!
05/22/2015 11:33 AM
Right!
At least they did finally fix that problem where you had to finish your entire post in something like ten minutes or start from scratch.
I very commonly start a post, then either get interrupted, or go off to do some research before continuing, so I definitely appreciate that fix.
My biggest complaint now is the inability to attach full-resolution images/drawings.
05/22/2015 11:55 AM
That would be a nice feature, I don't know how many times they are totally useless....
Even a doubling of the pixels would make a big difference.....but four times would be best!!
If all drawings were removed after say 3 months, that might be a good move!!
Good Answers: 137
05/22/2015 12:16 PM
Agreed about your complaint. Somebody explained to me a few years ago how to attach images and I managed it once, but it was so complicated I soon forgot, and I concluded it's more trouble than it's worth.
05/22/2015 1:45 PM
Images are easy, but the resolution is pretty bad, no matter what you post!!
05/22/2015 2:19 PM
I have to add a caveat to Andy's last post:
Attaching an image (.jpg or .png) is easy as long as you are using a browser that supports the CR4 toolbar. I don't know if the limitation is due to a weakness in Safari or in CR4' programming, but there is no tool bar when viewing CR4 in Safari. The lack of the toolbar makes everything but straight normal text more difficult. I normally use Firefox, but there was a problem in Firefox for a few days last week that made me use Safari. Fortunately, the Firefox issue disappeared, and I'm successfully using it now.
If by chance you are using Safari, try something else.
As Andy hinted, after attaching an image, you have to drag a corner of it to the right in order to get a reasonable size.
I really wish we could attach full PDF documents!
05/22/2015 4:39 PM
Agreed.
I have neither used Safari and the only problems I get with Fireox under Ubuntu is if I leave FF open and shut don in sleepmode. After a few times its just totlly locked up and I need to re-boot!
DKW is absolutely correct, only drag a corner of a picture, or you lose the height to width relationship.
I recommend the lower right corner.
Also drag it beyond the editing area, so that you end up with the maximum possible size, it may then be possible to (just!) read any included text (if you are lucky!!)
I have (mostly) given up complaining to CR4, as nothing ever gets corrected (mostly anyway! Look how long that timeout problem took!!).
05/22/2015 12:55 PM
HE used WAAAAY too much gas.. I have seen You Tube videos on "redneck mechanics", or something like that , that shows the proper method… One actually showed a guy running a truck on fumes from a gas can directly into the carburetor, gas line disconnected, revving up the motor, and to prove it wasn't a trick, started to cut off the flow of fumes, and you can see the engine rpms dying off. Claimed he ran lawnmowers, drove his truck around etc. using this method….. ..You may want to look around ..
05/22/2015 12:40 PM
He told us to stand back, put a small cap (Soda bottle) of gas into the tire, lit it with a match, (Held the edge down, threw the match in at the same time he let go), and POOF.. it seated..
Good Answers: 102
05/20/2015 11:57 PM
No spare seriously?
I remember when those tiny spare tyres were being introduced as spares and now they've gotten even stingier...less weight I guess.
What happens if you rip a side wall when your miles from nowhere? No can of slime will help you there or a tubeless plug kit for that matter.
I carry two full size spares and a tubeless plug kit in the glove box too. 4x4 field pickup truck, so weight and space are not an issue.
No spare.....what other signs of progress have I missed?
05/21/2015 11:41 AM
The spare was found to be flat due to an old , cracked valve stem. I had the guy also put an inner tube in the spare, until I could get the rig home. Remember, this was a 1963 VW bus, ,1500 cc engine, with tires deflated, at times, to 12 lbs for off road deep sand, and fine powder use. Not a lot of extra space and oomph for much more gear. Also had to pay of the Mexican Federale official in Ensenada , who said I failed to stop at a Hospital crosswalk 3 miles back!!! Again, $20 in a handshake made the deal, but he was polite enough to ask if I was left with enough money to buy gas to get back home. The USA always looks better upon returning.
05/21/2015 12:49 PM
As a "get-u-home" its OK, but on principle, you should NEVER put a tube in what was a tubeless tyre. It can suddenly lose air pressure.due to the rubbing of the roughly finished tyre inside surface against the tube.
Makers of tyres don't bother to smooth the inside of the tyre for tubeless ones....
Every time a (any) part of the tyre passes the "ground" it moves slightly in relationship to the tube.......a rubbing action.
If you HAVE to do it, use maximum allowed tyre pressure to reduce the amount of "rubbing" to a minimum!
Tubed tyres are made with a smooth inside for that reason, but eventually they wear the tube as well....
Hopefully its not a problem before the tyre needs to be replaced anyway.....which is why I dislike tubed tyres on principle....
05/21/2015 1:05 PM
Good points--At that point in time, any port in a storm thinking took over.
Good Answers: 117
05/21/2015 12:29 AM
much of what you've experienced from tyre shops is dependent on where you are in the world.
As you've spelt 'tyre' the English way, i'm going to presume you are in the UK or somewhere near.
So the rules regarding replacement tyres in the UK are different from the USA, and much of what you've read as replies are US based. In the UK tyres are repaired but usually under protest and with no real backup regarding longevity of the repair. Many years ago, a inner tube would have been the way to go, but the Ministry of Transport banned them.
One reply did say it would depend on the location of the damage to the tyre... yes. tyre walls cannot be repaired, and a new tyre is the only option.
furthermore, the foam may let the tyre run at a lesser operating pressure, hence the speed and distance warnings, therefore causing further damage to the whole tyre. You also have to remember that the reason that tyre shop now refuse to make repairs is they are liable in law for the repair and any accidents that a faulty repair might cause.
On a personal note, it's your daughter.... I value mine at far more than a cost of a new tyre!
05/21/2015 4:00 AM
I agree with the point you make concerning valuable daughters. The issue was not with the limited life of the temporary repair but with the refusal to perform a legal and safe permanent repair.
Good Answers: 117
05/21/2015 5:10 AM
You said..
I got that... and that is where you have to leave it up to the experts, as I said they have government guidelines to follow, as we live in a "Nanny State" and can't tell the difference between good and bad.
you would have a huge mountain to climb trying to prove any different, if they say it can't be repaired, I doubt if you will get anyone to say otherwise, not even the RAC or AA
Good Answers: 94
05/21/2015 5:35 AM
It's not even the difference between good or bad, the difference is often whether the insurers can apportion blame or not. If not, the advice is just don't do it.
Good Answers: 102
05/21/2015 2:26 AM
Good Answers: 102
05/21/2015 2:38 AM
05/21/2015 5:55 AM
The only normal reason to use such a can is when say your daughter is in a very suspect area, alone, that she needs to get out of quickly.....otherwise its too expensive, unless she buys her own tyres of course.
In such cases when a tyre is punctured, a decision has to be made how to act, much easier is when a proper (or even emergency) spare wheel is carried, AND she has the right tools (including light!!) for her personal strength and she knows how to use them without killing or injuring herself.....especially at night!!
I only used the spray cans once, probably mid 1970's or perhaps a tick earlier.
I had Mazdas at that time and their wheels always came with inner tubes, which I use only on push bikes, otherwise I avoid them....So when they were worn out, I replaced all 4 tyres with tubeless.
But each wheel lost small amounts of air per day, I only guessed, but I was sure it was the welding of the steel wheel parts that Mazda could not get quite right at that time......Porous.
I used about a quarter of a single can of sealer on each wheel (the spare was still new and still had an innertube!) and never ever had a loss of air (or a puncture!) ever again....
In those days the sealant was simply "good to go forever...."
It explained on the can that if ever a new hole developed, the sealer would then seal that too, for some years!! I had the car for at least another couple of years more, never any problems with punctures.......that is not a guarantee. But I might have had some......who knows?
May I suggest that you buy a proper spare wheel, put it on the car where the puncture was, the punctured one use as spare in the car and drive, keep an eye each week on the spare.....but I bet it never goes down on you!!
I think that the sealer company is just covering is rear end, just in case....understood?
You could even buy a tyre repair kit and put a plug in yourself (assuming you can find the hole! and use it as a spare only.....the sealer itself is really only a strong rubber glue with fibers.....
May I also suggest, for any vehicle you have, pump up the tyres to the max legal for a full load for that car, you will notice its a bit harder sprung for the next few days, but the rewards are lighter, more directional steering, lower fuel consumption, lower tyre wear, always ready for a heavy load and in my opinion only, a far lower likelihood of a puncture!! One only in the last 25 years, counting two cars at anyone time till 2006, then only one....retirement!! Still no punctures!!!
05/21/2015 8:41 AM
All the fuss about tires and SUVs rolling over has made everybody jumpy about repairing tires in General. The largest industry on the planet today in terms of monetary control is the insurance industry. I buy "string" repair kits, I have a nice one with CO2 cylinders for filling the tire.
Good Answers: 97
05/21/2015 9:44 AM
What bothers me about punctures, is the possibility that air pressure can intrude into the delaminated structure. I suppose the compounds used in the spare-in-a-can. would be able to fill these intrusions to a point, but not to the extent of the fissure. In any case, purely temporary.
CRTL-Z
05/21/2015 12:42 PM
Liability, ask a couple of lawyers. Also, ask the service dept of the brand of car that supplied the foam. -- JHF
05/21/2015 11:17 PM
Rather than fix or change your tire ( tyre, for our European or of European ancestry friends) how about, calling " road service". In California, we have the AAA, American Automobile Association, this is a company that provides auto insurance and other services, they also provide road service when your car breaks down or when your daughter's car gets a flat in the middle of the night in a bad part of town, She wont have to get out of her car or worry about lifting heavy Tools and a jack, she just dials 1-800-400-4222, and a service truck will be there soon. My wife and I have this service for less than $30.00 a month / peace of mind
Good Answers: 94
05/22/2015 4:12 AM
$30/month!!! over here that's the yearly cost of breakdown cover.
05/22/2015 4:49 PM
Nigh,
He's in California! The land of milk and MONEY!
Good Answers: 94
05/23/2015 2:30 AM
I probably have better breakdown cover than most people. I always use a breakdown company who give the franchise to a local recovery outfit where my son is the recovery manager, the service is 1st class.
05/22/2015 5:34 AM
When you have to be at work within the next half-hour, waiting for roadside help is not an option
05/22/2015 12:44 PM
We only spend approx. $110 per year, for 2 cars, and also get 100 miles free towing …AAA is the service, in California… We used them for locked out, key in ignition, flat tires for my wife and daughter, a tire replacement on my work truck after a side wall blow out on a very crowded freeway, a 35 mile flat bed tow after my oil pump went out on my Tahoe. Like they say, don't leave home without it, at least in crowded Cali….
Register to Reply 57 comments
adreasler (1); Andy Germany (10); brich (2); C-Mac (6); Circuit Breaker (1); Codemaster (3); dkwarner (6); Doorman (1); harley (3); jhotmer (1); Massey (1); Nigh (4); Original_Macgyver (3); phph001 (3); SHOCKHISCAN (1); SolarEagle (1); texasron (1); tonyhemet (2); Unredundant (3); Wal (3); Yahlasit (1)
