Previous in Forum: Takata Airbag Recall Doubled   Next in Forum: Is This a Scam or What?
23 comments
Electric Self Rotating Wing (UNIT) for E.V.s
05/21/2015 7:56 AM
Built R/C version to Promote E.V. Cockpit/Power supply! 1st Flight Test! Collar @ Base of Shaft Moved! Shaft to Hard for Set Screws to Bite Shaft Not Even Scratched Dimpled Shaft Problem Solved! A Bit to Much weight with Wings,Batteries,ESCs & Motors! OK Now Shaft Holds even with Screws Loosened! Next Test Friday or Sunday See it on You Tube! See Malfuntion Looks like Wings are Tail Heavy But Balance @ Chord Line Shaft Dropped Increasing Pitch Beyond Lift to Stall Angle! It will Make a Great UAV!More Speed Brake than Lift Angle!
Pathfinder Tags: R/C Electric S.R.W.
Re: Electric Self Rotating Wing (UNIT) for E.V.s
05/21/2015 8:06 AM
Your excitement is delirious...!!!
05/21/2015 8:48 AM
"... Increasing Pitch Beyond Lift to Stall Angle."
Offhand, it sounds like this might be a little problem.
The long white part (airfoil profile, skinned with a repurposed bedsheet): Is that one of the rotors? Sort of looks like chord to length ratio should be considered more thoroughly.
05/21/2015 9:19 AM
No, Problem! It's Covered with Boat Shrink Wrap! Wing is From Piper Cub ! Added 10"s to Each Side! 10" Props. on Typhoom Inrunner on Each side with 2200 Battery in each Wing! See Video! & Watch Next video of (FLIGHT)!
05/21/2015 9:22 AM
Pic. of Full Size version was Posted by Mistake? That Ended 20 yrs. ago with Neck Injury Limiting My Upper Body Strength!
05/21/2015 10:25 AM
Why so many plings!? Do you speak like that!? If so, it must be very strange conversing with you!
05/21/2015 11:33 AM
No, It Just Beats a Period! I Think I'm going to Make another Flight Test Today! Instead of Test Flight Previously! I will put it on You Tube for you! Started around Christmas But, Part Time Took a While I can Sleep in My Bed Finally! It's been a Parts Dept. since XMAS Can't Send video of Failed Flight Test But you can see it on You Tube Charles Glazebrook & Twitter rotate1953 I Really Think Today is the Day? I don't know anything about computers & Don't know what URL is to Send Vid.? See Hillers Hornet & Vid. of 1st Electric version in 50s Powered by Long ext.Chord! Only seconds of Video Seen After Starting My Project. I came up with the Idea while sitting Home with Neck Injury & Learned enough about computers to send simple email I'm calling It My (Corvette of Copters) I'll Make another vid. Today? Hopefully!
05/21/2015 12:56 PM
I agree with SolarEagle: your enthusiasm is, at the very least, remarkable.
I've watched your project on your varied threads - I'm sorry buddy, but I'm having a lot of trouble following what you're up to (wings off of a Piper Cub? That just has 'Bad Idea' written all over it).
Good luck to you, don't get yourself hurt too badly, let us know how it's going.
05/21/2015 3:56 PM
Just Put it Together & Ran it Outside! Batteries Need Charging. But, Shaft stayed in Place!Had Nobody to Vdeo on My Phone But, A Friend got Some of it I'll send it or Put it on You Tube!
05/24/2015 1:16 PM
I Think All of You will Understand My Enthusiasum? When you see Video of 2nd.Test! Neither Battery has been Charged Yet & 1 Shorted During Build when a Friend Soldered Pos. & Neg on Plug WRONG! Burning 3' of Ext. chord & Smoked an 80 amp. Red Brick ESC! Now that Shaft Problem is Fixed, Rotation is Excellent! Contacts Worked Perfectly!I don't Know the 1st. Thing about This Radio Pitch Curve Throttle Settings Sub Trim? I wanted Some Neg. for Auto Rotation & Thought I could Trim It? But Neg. Forces Must have overode Servo? Anyway I Think This Video will Generate alot of Interest in the Concept! The Video is on You Tube Now! Charles Glazebrook A Little Tweaking & Fully Charged Batteries Should Help! I also took off what amounted to a Baseball Bats weight! Oak Axles,3' 3/16 Steel Round Stock,3 3" Mag Wheels No Foam,Maybe 3lbsTotal! I May Even Leighten Wings Loosing Boat Wrap Covering over Balsa Skin & Recovering with Paper & Dope or Monocoat? May even Change props. to something else? 10x5 Pitch Now? Go to You Tube Charles Glazebrook I Think your Gonna Like IT! You Don't have to take My word for it Watch Video & Tell Me what you & Your Friends Think? This Test had Low Batteries Never Charged & Neg. Pitch Problem Those Fixed I Think it (WILL) Fly That Battery that Shorted Must be Low?
05/21/2015 6:20 PM
No! It doesn't beat a period! It is an indication of exclamation, not just the end of a declarative statement. (regular sentence)
I thought I saw some fuzzy photos here yesterday.
Most of the members here are older and learned punctuation and grammar when it meant something.
Take a deep breath, count to 10 and give us some good pictures and a concise explanation of the project. It sounds interesting.
Welcome to the forum.
05/22/2015 7:18 AM
Older than Me I'm 61 Was Flying r/c until about 20 yrs. ago Got neck Injury, When a 200lb. Piece of Steel Fell about 13' & Landed on Me Hitting shoulder & Neck.Had to have Tendon Superspynatus Reattached & Blew out Discs. @ Heart & Lung funtion Level! No Sugeon will go Near It! Tried before with POOR Results?I sent 1 Fuzzy Pic. by Mistake of a Full Size version I was working on @ That Time! That Ended with Injury.That Friend Left for N.H. without sending Me the Vid, He Took? I'll let you Know when I get Video of It in Flight!
05/22/2015 7:35 AM
Wow. I had you pegged as a kid. Sorry.
I've got you beat by 7 years.
We'll be waiting for the pics.
05/22/2015 1:47 PM
I've Also got about 200 hrs. Flying Time Logged In High & Low Wing Single Engine Aircraft Stopping @ Cross Country! Got to Solo & Had alot of Fun Flying Out of TewMac! I New Warren Hupper Pretty Good! Grumman Trainer,Piper Cherroki 6 cyl. & Piper Cubs! A Good Friend Flies for Commercial Airline! His Father Collected Biplanes! Uncle Part Owner of Beverly East Side! Had it Out Yesterday with Low Batteries. Pitch is In Neutrl Now! Nobody to Vid, Anyway! While waiting I'm going to Drop some Weight Like Oak Axles & Wheels! Total Weight Now is about 11 lbs.?
05/22/2015 11:42 AM
Listen, dude, slow down long enough to really think out a complete thought (a sentence), and then type it down in a complete thought (a sentence). When you string your thoughts altogether that way it either makes some of us have attention span deficit disorder, ADHD (attention decifit head-banging with hand disorder), or it is a sign that you have riddles and ADHD. Sorry for the bluntness, but I know you can do better than that. Happy for you that you are able to make progress on your project. I hope you experience success in that goal of seeing it fly (controllably).
The easy way to send a link would be to try this: Navigate to whatever web page (Ya'll Tube, or whatever) the video is on, or the pictures. Highlight the browser window tag bar at the top of the screen, then copy it. Now paste the link into one of your replies on this blog.
06/01/2015 8:04 PM
Many pics. on Twitter rotate1953 Going to Recover Wings Originally from Crashed Large Scale Piper Cub!
Good Answers: 445
05/21/2015 6:53 PM
Just don't try it near the White House!! Too many drones there already
05/21/2015 11:34 PM
And the White House doesn't accept air mail either!
05/22/2015 10:08 AM
This is the continuation of the saga on another thread. I expect to see the pigs flying before this does.
05/24/2015 2:19 PM
Watch Video on You Tube Charles Glazebrook! Then Talk to Me 2nd. Time Out and I'm Totally Impressed! Had Neg Pitch for Auto Rotation that Overode Servo Holding Slightly Neg. Batteries have NEVER been Charged & 1 Shorted Out for about 5 seconds when a Friend got Battery & ESC Pos & Neg crossed? Burbt 3' of ext. chord & Smoked 80 amp.Red Brick ESC So that Battery is Low for Sure I Also Removed what amounted to a Baseball Bat of Oak Landing Gear & 4 Rubber not foam 3" Mag. Wheels This Will Fly Dispite Your Remarks! I can Change Wings & have Thin Pair allready made with Same Dim. & Outrunner motors See them on Twitter rotate1953
05/30/2015 9:18 AM
Hope You Watched Vid. Of 1st. & 2nd. Test? I'm Sure you Know Now that the Concept is a Very Efficiante one! 1st. Time Out Collar Slipped Pitching Allmost Staight Up. Shaft not even Scratched Too hard for Set screws Shaft Not even Scratched.Dimpled Shaft OK Now! 2nd. Time Out Neg. Pitch Put in for Autorotation to Work. But,Wing Overpowered Servos & Held Neg.! If I could have Pitched Up Even Slightly? It would have Lifted! Dropped 5-7 lbs. Landing Gear Oak axles = Baseball Bat,3' 3/16 Steel Round stock,4 3" Mags & Rubber Tires,Steering Bellcrank linkage & Servo And a Handfull of Collars! Removed Boat wrap Over Balsa Covering & Most of Balsa.Replacing with Monocoat Film! 3rd. Time's a CHARM! Plagued by Small Problems New Improved Mixing Arms Should Fix this (Last) Issue? Watch for Next Vid. I'm Sure it will Fly NOW! If you've seen Videos You Know it WILL! Just, Built a Bit TOO Durable! See Hillers Hornet & Hiller & Bell 1st. Vid. on You Tube Single Tail Fin Axis control Other Videos of People Using Pie Plates! I don't Trust Anything that Can't Autorotate or Glide? Quads,Tri Copters & Dual Lifting Tilt Rotors & Others! Ounce Tweaked, This will be a (Corvette of Copters) & Safe as a Stork! Batteries will Get Charged for 1st. Time! Been Using them since Xmas & Shorted for 4 seconds During Build! I'm Sure they are Low @ Best Even Slowing Motors During last Test! This (PIg) Just, Needed Jenny Craig Weight Loss to Fly!
05/30/2015 8:03 PM
Even If You Insist On Capetalizing Every Word! And Splitting Up Your Sentences In A Strange Random Way! If You Want Anyone To Read Your Posts!
Break Stuff Up Into Pargraphs!
05/30/2015 9:36 PM
I'm New to a Typewritter & have a Hard enough time with Spelling.Also Dyslexsic as a Child until 4th. Grade when I got Caught.Writting Upsidedown & Backwards? Had to write Proper after that! But, Todays Helis. Seem Dyslexsic by Comparison? Hope you Saw Both of My Videos?
06/01/2015 12:31 PM
Do you actually have videos up on You Tube or something? Could you actually copy the link to them and paste it in your reply, so we don't have to "datamine" the entire internet to find them?
I am reminded of a story of a gentleman in Seminole, TX as the bus depot. He asks the clerk: "What time does that bus leave for Hobbs, NM?" Clerk replies, "That bus departs at 5:00 p.m. sharp!" The old gentleman asks the clerk one more question, "When does it arrive in Hobbs?" Clerk replies, "That bus arrives in Hobbs, NM at precisely 5:00 p.m.! Would you like to purchase a ticket?"
The old gentleman: "No thanks, I will just sit down here and watch that thing take off!"
I hope no one in here is time zone challenged.
Register to Reply 23 comments
Doorman (2); James Stewart (2); JohnDG (2); lyn (3); phph001 (1); RAMConsult (1); rotate1953 (11); SolarEagle (1)
