Previous in Forum: Why an Arrow Mark in Measuring Tapes at 16", 32", and So On   Next in Forum: Why isn't Fiber Optic an Option for Monitor Displays or Graphics Cards?
Pressure Measurement
06/10/2015 6:58 AM
I want to determine the pressure rise occurred in a room of a volume V by pumping more amount of air into the room without a way for the air to go out. Are there any formulas to measure this pressure Rise. Please Help me......
Good Answers: 73
Re: Pressure Measurement
06/10/2015 12:23 PM
Sure....assuming that the pressure increase resulted in negligible temperature increase then P1 = M1*V1, where M1 is the initial mass, P1 is the initial pressure, and V1 is the initial volume.
If you know P1 and V1 then the thing you can measure is the mass. Realistically that is going to be unrealistic.
If you are going to pump more air (i.e. more mass) into an air tight room, then the pressure will be a function of the increased mass and volume. More than likely, this homework will probably have the units of measure for the volume of gas to be pumped into the room as something like X liters. Then all you need to do is to determine the mass of X liters and do the algebra.
06/10/2015 6:30 PM
Is this the same room in: Calculations Regarding Indoor Air Mixing....
This is looking more and more like homework!
If so the formula given by NUOJ should be all you need.
PS: Rooms don't make very good pressure vessels.
06/11/2015 11:39 AM
0.5psi is enough to knock over a brick wall. 3in water gauge will prevent getting the door open, or seriously hurt someone who turns the knob and gets the door in their face.
You're really scaring me.
Good moaning!
Register to Reply 3 comments
Crabtree (1); lyn (1); NotUrOrdinaryJoe (1)
