Previous in Forum: Pressure Measurement   Next in Forum: Carbon Aero Gel
26 comments
Why isn't Fiber Optic an Option for Monitor Displays or Graphics Cards?
06/10/2015 1:17 PM
I do not know anything in this subject matter, so please excuse my ignorance.
As my 12 year old son and I were plugging in our new stereo and TV to each other, he asked me, " If optical cables are so much better then regular cables, how come they don't use them to connect everything back here, even the computer monitor?
Can anyone enlighten our curious minds?
nivek2421
Pathfinder Tags: Optical cables Toslink
Re: Why isn't fiber optic an option for monitor displays or graphics cards?
06/10/2015 1:34 PM
Some optical cables are used.
stereo+optical+cable
It depends on the signals to be processed, power requirements, and existing communication protocols. An optical signal is generated by converting an electrical signal into an optical signal at one end, then converting it back at the other end. Sometimes there's no reason to add that complexity to the overall system.
Good Answers: 266
06/10/2015 2:09 PM
Optical cables are not as good as HDMI in hi resolution audio. Blu-ray: Dolby TrueHD and DTS HD Master Audio formats can not be transmitted by optical.
Good Answers: 125
06/10/2015 2:43 PM
"Audio formats can not be transmitted by optical."
There must be some exceptions to that. I have a sound bar mounted above my TV that connects to the TV via optical cable.
06/11/2015 10:27 AM
Um, you clipped at the wrong point for your quote, that's why it didn't make sense to you.
"DTS HD Master Audio formats can not be transmitted by optical."
Lower fidelity audio signals CAN be send over Optical, but the higher fidelity signals need more bandwidth than fiber can provide.
Good Answers: 125
06/11/2015 12:50 PM
This technical paper by Dolby seems to refute that.
Good Answers: 12
06/11/2015 2:15 AM
What?? Really? Wrong.
06/10/2015 2:56 PM
Different connections are used with different formats and have different capabilities....some manufacturers have agreements with certain format providers...
Here's a list of format and connection types with their capabilities...
http://www.ramelectronics.net/howto-av.aspx
06/10/2015 3:11 PM
Copper's cheaper, more reliable and the band width requirement usually isn't there.
Good Answers: 50
06/10/2015 4:10 PM
GA.
There's lots of complexity in taking a relatively low bandwidth signal, (that are transmitted over the short distances of consumer electronics usage) and converting the signal to photons, sending them down a fiber, and then reconverting back to electric signals. Copper connectors and harness build, is simple compared to doing this reliably and cheaply using plastic or glass fiber methods.
ignator -
Re: Why isn't Fiber Optic an Option for Monitor Displays or Graphics Cards?
06/10/2015 6:50 PM
For the same reason you don't need a 6 lane highway into your garage. It would be overkill!
06/11/2015 10:30 AM
But where am I going to park the dozen or so 'trophy cars' to make the neighbors jealous?
I *NEED* that 6-lane highway to show off the cars .. that ... I ..... don't .... have ... ... ...
(Gilda Radner voice) "Nyever Myiiind..."
Good Answers: 75
06/11/2015 12:00 AM
To all the other answers to date, add these, from one who has been forced by requirements to do, or attempt to do, the engineering at a system level in order to accomplish exactly what you are questioning (in order to design "ultra-secure" communications into existing or new military comm systems):
1. It is expensive to add the necessary circuitry to convert from copper to fiber and back again (more or less hinted at by several, but not clearly enumerated) and it thus adds cost for no particular reason to the system
2. Every conversion from one data format to another causes gain in noise in the system, whether that nose is realized as "video cruft" or actual audio noise
3. More circuitry equals more opportunity for system chokepoints and failures.
All of the above have been more or less stated or hinted at. My answer is in no way intended to take or derive any recognition from those who've gone before. I am merely attempting to summarize clearly what the others have stated in many other ways.
In short, it ain't worth it, and it would only sell to those who are always ready to spend more in order to buy specifications neither they nor any other (non super-)human can see or hear.
Good Answers: 12
06/11/2015 2:14 AM
Being in the fiber optic modem industry (R&D and manufacture) I would say that the cost is the largest deterrent. The real question to ask is "Why would one use fiber optic transmission?" of anything. Distance, security and noise immunity are the key reasons to use fiber.
Transmitting any signal over a long distance is susceptible to signal degradation and injected noise. Fiber would be ideal as it is immune to external noise and signal loss over distance is very small. A said monitor is no more than a metre or two away from the PC. It would be pointless to add (as someone mentioned) extra conversions for the sake of doing so.
Security is also a big issue as one cannot simply "tap" into a fiber over any distance. Again, since the monitor is only a short distance, securing this link would be pointless.
I will challenge anyone to say that any other format (HDMI etc) is better than fiber - as someone eluded. We design and produce many industrial modems that transfer data through HDMI, SDI, DVI, HD, audio, data, analgue video etc. The choice really is "horses for courses".
An example of one of our products in use is a PC monitor at a railway station. The PC that runs the platform displays is typically >100m away. Using copper/coax would render the screen "noisy" and also EMI from passing trains could produce distorted images. Our underground railway stations employs our products to head up a crystal clear display for the commuters free from "noisy" screens.
06/11/2015 10:46 AM
"I will challenge anyone to say that any other format (HDMI etc) is better than fiber - as someone eluded."
Such an open-ended statement is folly to anyone who thinks things through. It's the equivalent of saying one format is 'best' without giving the conditions tested.
Let us look at a simple example, from the realm of Fantasy games. You typically have four hero types, or 'classes,' the Fighter, the Thief, the Wizard, and the Cleric. Which is the best?
The Fighter has the strongest arm, and can do the most damage when going toe-to toe with the marauding hordes, but can he dispatch the foes standing back and firing at him with longbows? Sadly, not.
The Thief is expert in stealth and camoflaguge, able to sneak through the shadows and underbrush without a sound, and can dispatch almost any single foe with a well aimed dagger to an unprotected back, but if he is spotted before he can strike, he is all but defenseless against retaliation.
The Wizard can call on arcane forces to smite foes from great distances, but when the battle becomes close, he is as helpless as a member of the Chess Club surrounded by angry members of the Football/Rugby team.
The Cleric has some battle skills, just enough to keep himself from being a liability in combat, however, his true skills come in being the Team Medic, healing the injuries of the others so they can fight on when otherwise they would have fallen.
Each is the 'best' at what they do, but no-one is the 'best' at everything. It is the same with the transmission formats, no single one is 'best' for every situation, so each situation requires a different format.
06/11/2015 2:49 AM
Some of the reasons above are thru, others are just a guess in the wild.
Optical fiber cables are not more expensive than copper, in fact they are cheaper.
Putting a plug on them is the tricky part in the whole cost picture. (requires specialised equipment and trained operators)
With POF some of the issues are omitted and solved. (Plastic Optical Fiber)
Still remains indeed the transfer from the electric signal in the computer to the optical signal: this part is indeed an overkill.
The missing speed requirement is indeed another factor.
The whole problem is latency: it is difficult to change a functional system.
Most computers have HDMI and DVI exits, and most projectors/monitors also, still we see those stupid, problematic VGA cables being used. (even using HDMI to VGA converters)
But it will change: there is big international effort to do optical communication on the main board to overcome actual bottlenecks that starts to limit computer to perform faster. higher definition screens will require higher speeds also thus requiring higher bandwidth cables.
If the IC's intercommunicate optically in the near future, going back to electricity would be an avoidable cost.
My proposal is to create a new inter device connection system based on Optical communication: it could replace all other cabling options.
Optical USB but even more versatile/universal: put it between two computers and they could build a network, from a computer to a screen and the screen tells the computer it is a screen so the specific sockets are installed to couple that port to the graphics processor (or even move the graphics processor to the screen and use X11 style graphical engines)
In fact all devices are computers so they can tell each other what they can do for each other: external hard drive, printer, screen, keyboard/mouse (please do this wireless) endless list.
Hobbies - Musician - New Member Greece - Member - New Member
06/11/2015 5:19 AM
Fiber cables have the following advantages:
1) Very high BW (in other words, high data rate)
2) Low attenuation (signal transfer on higher distances)
3) No electromagnetic (EM) radiation / infinite EM immunity
4) Communication safety (difficult interception of data)
5) General safety issues (e.g. no danger of fire in areas with flammable materials)
6) No crosstalk between adcacent optical lines
They, also, have the following disadvantages:
1) More expensive compared to the copper cables
2) Higher complexity (electronic circuits are included in order to convert electrical signals to optical signals and vice versa) reducing the reliability compared to the copper cables.
So, as you can see, for lower bandwidths (like -e.g.- Hi-Fi audio signals or relatively low data rate of your computer) it's much cheapper and simpler to use copper cables. As an example, even for the Gigabit Ethernet connections (1Gbps) we usually use twisted pair copper cables for relatively low distances (however fiber cables are also used mainly for high distances). For higher data rates though (like 10Gbps or 100Gbps) only fiber cables are used due to the very high bandwidth of these signals. That's why, in general, copper cables are used in most commercial and home applications. Fiber cables are mainly used in the large backbone networks (where huge amounts of data are transfered in very high speeds) or in other special cases due to their advantages (already mentioned).
George
06/11/2015 11:07 AM
I have to counter claim 5: due the high concentration of energy (light is energy) optical communication cables are not assumed to be harmless in classified area's and need to be treated as all other spark sources.
06/11/2015 2:45 PM
Fiber optic cables are NOT a source of sparks.
Fiber optic cables may cause flammable cloth or paper to ignite because of the intense light beam, usually associated with fiber optic illumination systems used in hospital surgery rooms.
06/11/2015 3:54 PM
SSorry, I got lost in translation: they are indeed not a source of sparks but they need to be treated as spark sources are treated.
Regards
06/12/2015 3:50 AM
Hi Gwen. The "danger" of ignition of flammable materials is an actual danger only in the cases of very high power laser beams. Even for lighting purposes there is not such a danger (I'm talking about the usual flammable materials and the usual light intensities. Have you ever seen -e.g.- the ignition of such material because of a spotlight???) Moreover, here we are talking about fiber cables which transfer data or other signals. In such cables the power of light is just a few milliwatts.
George
06/12/2015 3:57 AM
I have to counter you here: it is not the total power but the power density which is important for ATEX.
I have been in a project where I had to make sure every connection had to be outside the classified area or encapsulated in an EXd enclosure. And we were only measuring the temperature of a pipeline, laser power was only 0.7 mW.
But this 0.7mW is contained in a 9µ zone in a FO cable
06/12/2015 7:46 AM
I was of the same idea until I was doing an intallation and got stopped: no ATEX certificate = no connections in the field.
It is true that the cable itself is safer, no risk of overheating due short circuit or so.
But it is the end of the cable, the connection where the issues can arise.
Some flammable products auto ignite at very low temperatures, that is why there are temperature classes.
In your home application they are safe. Enter the (petro)chemical industry and they don't "assume" it is safe, Enegy is enegry and heat can come from everywhere.
06/12/2015 11:22 AM
I agree about the "end of the cable" mainly because there is electronic circuitry over there (conversion from optical signals to electrical signals and vice versa). And several problems (shortcircuits, sparks , overheating) may arise in this circuitry. So, it's obvious that the "ends of the cable" (and the associated circuitry) must be located outside the dangerous area. My question is: Is there any safety problem if just the fiber cable (i.e. not its edges) is located inside a dangerous area??? Even if the cable is accidentally broken and a (e.g.) laser beam of a few mW is emitted from its broken edge, can this beam ignite a flammable material??? What kind of flammable material may be ignited by such a low light energy (paper, plastic, oil, gasoline)??? Do you have any info on that issue???
George
06/12/2015 2:35 PM
Please read #17 again.
06/15/2015 3:23 AM
Yes... so what???...
George
Good Answers: 122
06/11/2015 9:48 AM
The cost is too high.
The direction we are currently heading is to RF signal transmission that utilize conductor free components which do not use fiber or copper.
No messy tangle of wires/cables. YEAH!
Noise impingement and sound quality? Sometimes YUK!
Register to Reply 26 comments
adreasler (3); daffy (2); G.K. (4); Gwen.Stouthuysen (5); ignator (1); lyn (3); micahd02 (1); ozzb (1); Rixter (1); SHOCKHISCAN (1); SolarEagle (1); Usbport (1); WJMFIRE (2)
